Author Topic: New Heads VS total rebuild on C8OE CJ heads - Your opinions?  (Read 18174 times)
TorinoBP88
« on: March 16, 2016, 04:44:57 PM »
In light of the engine failure i had on Sunday, dropped an exhaust valve from a used set of CJ C8OE heads (unknown valves at this point) and beat up my 'new' 416 bottom end (link to story at: ( http://www.network54.com/Forum/74182/thread/1458099200/last-1458162466/View+Thread )),
My question is one that has been asked a dozen times before (but my perspective is different now!):
1) Do i rebuild these CJ heads (or a set of C6AE-R heads) with all new parts new guides and exhaust seats at least,
2) Do i buy a set of Edelbrock heads (or save up a little more) and get Survival or BT heads.
Re: New Heads VS total rebuild on C8OE CJ heads - Your opinions?
« Reply #1 on: March 16, 2016, 04:46:15 PM »
#2 gets my vote.
« Reply #2 on: March 16, 2016, 06:41:28 PM »
Sorry to hear about the engine failure.  I saw your post on the FE Forum and wondered about the failure's train of events.  I have never seen a valve just break in half without contact of some sort.  Not saying it didn't happen, just wondering if you saw any other evidence of contact, for example a bent pushrod, that may have indicated piston to valve contact prior to the break.  Also, was this a hydraulic lifter engine?  If so, are the clips still in the top of the lifter where the failure occurred?
Anyway, where you are now it seems to me that you would be money ahead buying a set of the Edelbrocks, swapping on your springs, and going from there.  Good luck on the repair.
FirstEliminator
« Reply #3 on: March 16, 2016, 07:36:55 PM »
   Does anyone make a set of aftermarket cast iron FE heads?
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
427Fastback
« Reply #4 on: March 16, 2016, 07:40:48 PM »
I just did a set of CJ heads.By the time I had new seats installed,had them surfaced got all new springs and retainers and new valves I probably could have bought new aluminum heads..Customer wanted the stock iron heads or I would have done it..
I am not a fan of CJ heads with hardened exhaust seats.Unless the head is shallow (counter)bored and a thin seat is installed the seat support is not 100%...JMO.
1936 Diamond T 212BD
1990 Grizzly pick-up
« Reply #5 on: March 16, 2016, 09:42:29 PM »
No, no aftermarket cast iron heads are available for the FE.
TorinoBP88
Failure details of broken valve
« Reply #6 on: March 17, 2016, 12:07:02 AM »
Jay,
Well careful looking and I found the exhaust pushrod was bent about 0.020".
More carbon on valve stem than I expected to see. Probably from the other guy running this 750 carb which is on the rich side. There was a slight witness on stem of possible seize in the house.  Stem broke like glass.
Found valves are all trimmed down hollow Sodium Valves labeled S 3-9!  I missed this... I never would have run them had I known!!! Wish my machinist would have replaced the valves when I asked him to. I guess he thought he was helping me save $$.
Live and learn.
« Reply #7 on: March 17, 2016, 04:50:23 AM »
Ouch! Yes, when new those sodium filled valves were the latest and greatest. Yet, years later, they ate away inside way too many great engines, Cammer's included, as they were time bombs just waiting to go off.
MeanGene
« Reply #8 on: March 17, 2016, 08:03:14 PM »
They might not be trimmed down, they made lightweights in CJ size too. Pip, I have a set, IIRC, of C8's that are pretty fresh that I don't need that could go pretty cheap. I do have an extra set of Ebocks but not sure if I want to give them up yet- if I sell a couple other things I'll probably hang on to them
« Reply #9 on: March 17, 2016, 08:11:25 PM »
As much as I love the old iron, I think I'd go for the Edelbrocks also. Those heads are still saveable though for someone who needs them.
TorinoBP88
MG: what does "IIRC" mean
« Reply #10 on: March 18, 2016, 12:02:51 PM »
MeanGene, What does IIRC mean.  C8 heads, are those chambers on the small side for a 428 (or a 462 stroker?) I would hope they are 8 bolt exhaust a well?
« Reply #11 on: March 18, 2016, 12:25:34 PM »
I'm not MG but...
'If I Remember Correctly' will get you in the ballpark.
Last I knew you could get iron heads from Dove but you'd undoubtedly have to order them specially made and it would probably take a year or more to get them. And to what purpose?
Iron heads are, by this time, only for those who MUST use them due to some sort of class rule.
KMcCullah
« Reply #12 on: March 18, 2016, 04:46:04 PM »
The curse of the sodium filled exhaust valve! Sorry to hear Pippin. Have you talked Keith Craft? I saw an ad he was running last year about offering CNC porting for iron heads. Maybe he can hook you up with a ready to run CNC ported iron head? And save you a few bucks.
Kevin McCullah
« Reply #13 on: March 18, 2016, 06:13:13 PM »
Or for the stubborn, or the ones who just want to prove a point, or who just want an all Ford iron engine, or are nostalgic. or.... :)
MeanGene
« Reply #14 on: March 18, 2016, 06:50:26 PM »
IIRC means you might have a touch of CRS- and hopefully not full-fledged CRAFT...
Pretty sure the heads are C8AE-H's, eight bolt set that was built fresh for a jet boat and only run a little. Should be able to swap to your springs and put 'em on
