Author Topic: Preview of coming non-FE dyno attractions...  (Read 30490 times)
« on: January 24, 2016, 10:25:23 PM »
This engine belong to my former trunk monkey, and is slated for his 31 Plymouth Drag Week car.  392 Hemi...
We'll be running this later in the week; I'll post the results when we have them.
Re: Preview of coming non-FE dyno attractions...
« Reply #1 on: January 25, 2016, 07:33:52 AM »
Nice! I guess your dyno does accept non-FE engines! Hah!
Can't quite read the end logo but what make are those aluminum 392 heads? Old 354-392 Hemi's are pretty cool in that they are simple and easy to work on. But man are those OEM iron heads h-e-a-v-y!
« Reply #2 on: January 25, 2016, 08:27:38 AM »
They say Hot Heads. Seems appropriate for a Chrysler owner ;D
Cool engine. Hopefully you'll post some details about the cam and heads also. Should be interesting to see.
JERICOGTX
« Reply #3 on: January 25, 2016, 12:40:53 PM »
I'll guess... 360hp. 300 with the funky 8 1bbl carbs intake.
57 lima bean
« Reply #4 on: January 25, 2016, 12:41:41 PM »
Is this the first non Ford Engine on the Dyno?
JERICOGTX
« Reply #5 on: January 25, 2016, 02:46:49 PM »
Maybe since Jay has owned it. It had a nitro burning chainsaw motor on it at one time. It has just about seen everything.
« Reply #6 on: January 25, 2016, 03:40:46 PM »
My first Drag Week co-pilot, Steve S, is a Chivverlay guy.  I'm embarrassed to admit that I've had a couple of his small blocks on the dyno.  On both occasions, he left the timing light clamp on the plug wire, and during the pull it slid down the wire, landed on the headers, and melted the clamp  >:(  My fault for not seeing that issue.  I hate those engines...
Joel has also had his FAST series Hemi on my dyno.  That thing looked bone stock, had the factory intake, carbs, and exhaust manifolds, and made over 700 horsepower.  I was mildly impressed  ;D
Joel is hoping for 700 out of this engine.  The heads are probably up to it, they flowed 390 cfm on the intake.  The manifold and carbs, on the other hand, might hold it back some.  Jeff (JericoGTX) is just hoping it blows up, because he knows if it does, Joel will never have it ready for Drag Week this year, and he will owe Jeff a steak dinner  ;D
Here are some more details on the engine.  Displacement is 468 CI, bore is 390 size at about 4.07", stroke is 4.500".  Cam is .700" lift on the intake, .650" on the exhaust, 261@ .050", 112 LSA.  Compression is around 11.5:1, and the induction system is some long runner crossram with pot style carbs on it.  I haven't seen the induction system yet, but my guess is that is what will be holding him back.  One thing that will help are the headers, which are my SOHC dyno headers, with a few extra holes drilled in them to bolt to the aluminum hemi heads.  The ports lined up nearly perfectly!  I told Joel that he was one cam short of an SOHC  ;D
When he has it nearly ready to run, we'll place our HP and torque bets...
« Last Edit: January 25, 2016, 03:43:30 PM by jayb »
57 lima bean
« Reply #7 on: January 25, 2016, 04:10:52 PM »
  Yes,that Dyno's a slut :)
    That engine is going to make the coupe a handful !!!!
JERICOGTX
« Reply #8 on: January 25, 2016, 05:18:46 PM »
I do NOT want to see this thing blow up and DO want to see it ready for Drag Week. I wish I had more time and enthusiasm to help Joel on it. Just flat out in a funk to do anything right now.
Hemi Joel
« Reply #9 on: January 25, 2016, 06:57:07 PM »
I know what will get you out of your slump. Let's reverse the bet. If the coupe makes it to Drag Week 2016, I'll buy you three dinners. If not, you buy me one.
427Fastback
« Reply #10 on: January 25, 2016, 09:51:17 PM »
Cool...I like 392's and have done a few.Looks like its running the pump adaptors and using a BBC water pump..Last one I did was topped with Webers...Nice engines
1936 Diamond T 212BD
1990 Grizzly pick-up
« Reply #11 on: January 26, 2016, 06:52:43 AM »
Ram style runners, eh? Maybe he's trying for the early Ramcharger's induction.
http://www.allpar.com/racing/high-mighty.html
shady
« Reply #12 on: January 26, 2016, 11:45:01 AM »
don't want to hijack, but search you tube for "extreme v8 chainsaw buick"  read an article in hotrod 20 years ago about this saw. don't know if linky works.
https://www.youtube.com/watch?v=uE0jnfJKNNU
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
« Reply #13 on: January 26, 2016, 10:41:02 PM »
Not that you need one Joel but just in case, have you seen this?
BBM is about to be reproducing 392s.
I was over there a couple months ago and snapped a few spy pics of the prototype.
Kinda makes me wanna build a front engine digger. :)
« Reply #14 on: January 27, 2016, 09:49:39 AM »
Wow, that is one clean looking casting, much better than an OEM 392 block. It's an interesting time for a modern 392 block as the popularity of cacklefest race cars is at an all time high. That and the resurgence of actual side-by-side racing of front engine AA/FD's in nostalgia classes where they are turning in the high 5's!
Would be great to see Bach & Gould or a new team field a real SOHC Ford nostalgia AA/FD again.
http://www.dragracingonline.com/special/bachgould_1.html
« Last Edit: January 27, 2016, 09:54:39 AM by machoneman »
