Author Topic: I've got a chance to buy a NOS Zoom aluminum FE Flywheel  (Read 5671 times)
FERoadster
« on: January 22, 2016, 11:30:42 PM »
for a decent price. Were they a well made product? I figure it was made in the late 70's-early 80's. 428 balance for my 428 crank.
On the FEForum my car weight and gearing/trans made it streetable. Car weight just under 3000#.
What's the quality? I'll be using a Lakewood Bell.
Richard >>> FERoadster
Katz427
Re: I've got a chance to buy a NOS Zoom aluminum FE Flywheel
« Reply #1 on: January 23, 2016, 06:14:37 PM »
Zoom was always a good brand back in the 70's / 80's. I remember that we used Zoom clutch and pressure plates in our oval track Ford with no problems. Should be a good flywheel.
XR7
« Reply #2 on: January 24, 2016, 01:53:50 AM »
As long as it has a steel heat shield riveted on so it is replaceable, if it is bonded on, or not a steel or bronze face (solid aluminum...) then pass on it.
FERoadster
« Reply #3 on: January 24, 2016, 05:24:12 PM »
I did check and it is riveted
So I'm going ahead with the buy.
Thanks  FERoadster
FERoadster
« Reply #4 on: February 19, 2016, 09:03:37 PM »
Purchased the Aluminum flywheel and it arrived today.
Sold on HAMB as a Zoom flywheel but the casting and sticker both say Weber and it's stamped #52510
What's the quality of Weber vs. Zoom  and is the 52510 for a 428 balance? There are steel balance weights in the flywheel that are about the same location (180~ apart) as the holes drilled in my Ford 428 wheel. Got to check that closer-------------- It does have a riveted steel clutch facing.
Thanks
Edit: Attached Pictures
« Last Edit: February 20, 2016, 01:37:16 PM by FERoadster »
« Reply #5 on: February 20, 2016, 01:41:30 PM »
Weber was a good brand back in the day; maybe Zoom purchased them or Weber was renamed or something?  I wouldn't be hesitant to use it because it says Weber on it...
« Reply #6 on: February 20, 2016, 02:17:55 PM »
+1 with Jay. 'Back when', Weber was as good as it got.
FERoadster
« Reply #7 on: February 20, 2016, 06:37:52 PM »
Jay and KS (Ken?) thanks. I had a Weber in one of my Model A's (SBC however) and it really revved quick. It was way too much a handful to drive with a 5.13 posi. Swapped to a 3.70 and SBF for a trip from Michigan to the Memphis Street Rod Nats. in 1975. The SBC is still on a stand in my shop here in Oregon.
Richard
