FE Technical Forum
Do SOHC Fuel Pumps use a unique plunger rod?
Topic: Do SOHC Fuel Pumps use a unique plunger rod? (Read 4061 times)
Qikbbstang
January 16, 2016, 07:01:48 PM »
I recall seeing something about a stub cam but what's/how's it drive?
http://www.ebay.com/itm/172002929154?ru=http%3A%2F%2Fwww.ebay.com%2Fsch%2Fi.html%3F_from%3DR40%26_sacat%3D0%26_nkw%3D172002929154%26_rdc%3D1
BH107
Sr. Member
Re: Do SOHC Fuel Pumps use a unique plunger rod?
Reply #1 on:
January 16, 2016, 07:17:30 PM »
Yes, they use a unique arm. The one in the ebay ad from Carl's isn't shaped quite the same as the originals, but it works. They drive off of an eccentric on the idler gear on the passenger side of the engine.
Autoholic
Sr. Member
Reply #2 on:
January 16, 2016, 10:40:41 PM »
Take a look at the idle gear near the driver's side cam gear. The offset metal ring, is the eccentric gear that powers the manual fuel pump.
~Joe
FE Technical Forum
