Author Topic: Do SOHC Fuel Pumps use a unique plunger rod?  (Read 4060 times)
Qikbbstang
BH107
Re: Do SOHC Fuel Pumps use a unique plunger rod?
« Reply #1 on: January 16, 2016, 07:17:30 PM »
Yes, they use a unique arm. The one in the ebay ad from Carl's isn't shaped quite the same as the originals, but it works. They drive off of an eccentric on the idler gear on the passenger side of the engine.
Autoholic
« Reply #2 on: January 16, 2016, 10:40:41 PM »
Take a look at the idle gear near the driver's side cam gear. The offset metal ring, is the eccentric gear that powers the manual fuel pump.
~Joe
