Author Topic: Oil Pumps  (Read 12646 times)
ChiefDanGeorge
Oil Pumps
« on: January 12, 2016, 07:08:02 PM »
Still gathering parts for my 390 build(390/40 over/4.125 stroker, cruiser/highway wagon). I searched the forum for oil pumps to see if anything shook out as what most people are using. Seems Milodon is one that came up a good bit.
Should I lean towards a high volume unit, or is an OEM pump suitable for what I'm doing?
Re: Oil Pumps
« Reply #1 on: January 12, 2016, 07:38:44 PM »
I recommend this pump.
The Melling M57HV.
If you want a really nice one get the M57HV from Precision.
http://stores.precisionoilpumps.com/blueprinted-melling-ford-fe-high-volume-1-4-pump/
http://www.summitracing.com/int/parts/mel-m57hv/overview/make/ford
This pump will read about 80 to 85 psi cold on start up and settle out around 65 psi when hot at 2000ish rpm.
Get a heavy duty drive shaft and you will have all the oil pumping you will need.
I like a mechanical gauge with a hard line to the gauge.
Do not use the plastic line that comes in the box.
Re: Oil Pumps
« Reply #2 on: January 12, 2016, 10:40:09 PM »
Yeah, I'm a fan of HV pumps and thinner oil.
For my oil psi gauges, I use -4 SS line to the gauge.  Edelbrock has a lil 1/8inch X -4JIC adapter that hooks into a gauge easily.
Qikbbstang
Drew "Yeah, I'm a fan of HV pumps and thinner oil."
« Reply #3 on: January 13, 2016, 08:45:02 AM »
In this day and age "thinner" oil can be a multi-viscosity a 10w-40.  Do you run a low viscosity oil or multi-viscosity?
ChiefDanGeorge
Re: Oil Pumps
« Reply #4 on: January 14, 2016, 03:08:50 PM »
Should I use restrictors in the heads with the high volume pump?
Re: Oil Pumps
« Reply #5 on: January 14, 2016, 03:24:05 PM »
I do and it makes me laugh how much oil is still up there.
Re: Oil Pumps
« Reply #6 on: January 14, 2016, 04:01:33 PM »
I use Melling HV pumps and have had excellent service out of them.
In my 351Cs I run VR-1 30wt or 10w-30, both have the same oil pressure and bearings look the same on teardowns.  It's usually 10w-30 because it's stocked locally and straight 30wt is special order.
Re: Oil Pumps
« Reply #7 on: January 14, 2016, 04:22:46 PM »
I use restrictors in my Ed heads. I tapped the oil passage for a 1/4" 20 set screw and drilled the set screw
with a 0.070" hole. I have LOTS of oil up to the rockers.
Re: Oil Pumps
« Reply #8 on: January 14, 2016, 04:32:31 PM »
*cough cough*
WELL, if you'd bought the FE intake comparo book, you'd note the oil level info in the back shows you all ya need to know about that.
Just messing Chief, but I think Jay has videos online with an oil sightglass in the pan with and without restrictors.  Made a believer out of me.
ChiefDanGeorge
Re: Oil Pumps
« Reply #9 on: January 14, 2016, 06:48:04 PM »
Man, I am drowning in info as it is! I appreciate the heads up though!
*cough cough*
rhinosoft
Re: Oil Pumps
« Reply #10 on: January 14, 2016, 08:59:19 PM »
Drew,
that is a pretty good video, link is here:
https://www.youtube.com/watch?v=9vcWvp_DIWA
Graeme
ChiefDanGeorge
Re: Oil Pumps
« Reply #11 on: January 15, 2016, 05:46:30 AM »
Is that with restrictors?
Drew,
Graeme
Re: Oil Pumps
« Reply #12 on: January 15, 2016, 09:47:42 AM »
Yes, that is with restrictors.  There is another video, which I think is the one that Drew was referring to, where I have a sight tube installed on the oil pan, and you can see the oil level in the pan going down during the dyno pull.  Can't find that one at the moment...
Cyclone Joe
  • Joe
Re: Oil Pumps
« Reply #13 on: January 15, 2016, 11:44:15 AM »
Here is a good overview of pumps and other oiling options for the FE: http://fordfe.info/Forum/Oil.html
ChiefDanGeorge
Re: Oil Pumps
« Reply #14 on: January 15, 2016, 12:38:08 PM »
Looking at the Figure 1 there, there are only 2 oil feed passages in the heads(1 per head)?
