Author Topic: Placement of driveshaft hoop on car?  (Read 10314 times)
GJCAT427
« on: November 25, 2015, 01:54:48 PM »
Okay is it set in stone where  the driveshaft hoop needs to be placed under the car? This is on my 64 Fairlane tbolt clone. The rear incorperates the hoop  on the traction bars but I believe You have to run one in the front to be legal  for NHRA class.
Re: Placement of driveshaft hoop on car?
« Reply #1 on: November 25, 2015, 02:03:59 PM »
IIRC the rules state 6 inches behind the front U joint.
Don't have a book on me right now tho'.
« Reply #2 on: November 25, 2015, 03:24:19 PM »
Marc is correct, with a little clarification - rule is WITHIN 6 inches of the center of front u-joint. So for example 2" behind, 4" behind, etc. up to 6" all good. Just pointing it out because sometimes a floor brace, emergency brake cable, and so on might be in the way at exactly the 6" spot. And although not required by the rules for most cars, a rear loop like you have is a good thing. I've seen race cars break a driveshaft in half and that foot or two of spinning broken rear shaft attached to the rear end will absolutely tear the floor out of a car until you get it stopped.
57 lima bean
« Reply #3 on: November 25, 2015, 03:51:23 PM »
Memories tell me it has to be 2 inches wide and of at least 1/8 inch thickness.
GJCAT427
« Reply #4 on: November 25, 2015, 06:12:13 PM »
Okay That works for me, I guess I made it overkill as it`s 1/4" material.
« Reply #5 on: November 25, 2015, 06:29:20 PM »
No, you did just fine. 2" x 1/4" if flat steel or 7/8" .065 wall welded steel tubing is the rule. I was remiss for forgetting that detail, thanks to Steve P. for bringing it up. And Steve's memories are legendary, but not always something you want to rely on ;)
IDOIT4SPEED
« Reply #6 on: November 25, 2015, 10:48:25 PM »
yes it is set in stone where it has to be. I switched from a top loader to a g force g101 and did not move the loop. the tech guy had a fit. it was 8 in from the u joint instead of 6 in. he said I could run it like that for the weekend, but you better have  it changed by next time you come back. I have moved it twice since. if you run an automatic they might not even look
« Reply #7 on: November 25, 2015, 11:15:45 PM »
How do you like the G 101 ? I'm thinking king of reading my jerico with one.
IDOIT4SPEED
« Reply #8 on: November 26, 2015, 12:54:31 AM »
  g101 was light years ahead of the face plate/pro shift top loader as far as shifting goes. for some reason the teeth would fall off low gear. got about 50 passes on it before it blew up the second time, total loss. I have a lenco now.
« Reply #9 on: November 26, 2015, 08:42:06 AM »
What do you think about the ST 1200 lenco, ? I have considered one of those as well, had a line on a jeffco last ear and let it get away from me  :-\
IDOIT4SPEED
« Reply #10 on: November 26, 2015, 10:03:50 AM »
it is the best performance part I have ever bought, yes its big and heavy. and it has a cool factor I never expected!
57 lima bean
« Reply #11 on: November 26, 2015, 11:34:04 AM »
"And Steve's memories are legendary, but not always something you want to rely on" ;)
Kevin....LOL Next thing ya know,I'll be telling true stories that never happened.
