Author Topic: Cam lobe damage  (Read 4503 times)
Cam lobe damage
« on: November 08, 2015, 07:36:41 PM »
I think this roller cam is usable with a slight soft cleanup.  It's the only damage and the rest of the lobe looks perfect. What do you guys think ? Is it usable?  How would you go about cleaning it up ?
Re: Cam lobe damage
« Reply #1 on: November 08, 2015, 08:25:20 PM »
Nope, need to send it back to mfg for regrind, or shelve it.  It will only get worse, and take out the next lifter you put on it very quickly. When a roller lifter lets go, bad things happen all over the bottom end. BTDT.  Joe-JDC
Re: Cam lobe damage
« Reply #2 on: November 08, 2015, 08:57:42 PM »
Looks too deep to scuff. What happened?
« Last Edit: November 08, 2015, 09:09:13 PM by Nightmist66 »
Re: Cam lobe damage
« Reply #3 on: November 08, 2015, 11:05:00 PM »
A roller axle failed and came partially out of a comp cams roller lifter. I have also had comp cams full skirt lifters crack or break, lucky not in a critical place but it's never good having pieces laying around in the engine.  I switched to crane lifters about 5 years ago that only has the partial skirt were the link bar goes and haven't had a problem since. I have never ran the morel lifters before but most of the guys here seem to use them so that will be my next set.
Re: Cam lobe damage
« Reply #4 on: November 08, 2015, 11:10:37 PM »
Thanks Joe. I was hoping to make a couple bucks, I'll pass the info on to the prospective buyer though. Maybe I can make a mailbox post out of it.. oh well.    :-\
Re: Cam lobe damage
« Reply #5 on: November 09, 2015, 05:32:47 AM »
I wonder if the cracked cam thrust plate was caused when the lifter went astray, jamming the cam's nose into the plate. Agree that that lobe needs manufacturer help in a big way.
