FE Technical Forum
Cam lobe damage
Topic: Cam lobe damage (Read 4505 times)
Cam lobe damage
November 08, 2015, 07:36:41 PM »
I think this roller cam is usable with a slight soft cleanup. It's the only damage and the rest of the lobe looks perfect. What do you guys think ? Is it usable? How would you go about cleaning it up ?
Keith. KB MAX Racing.
Truth stands on its own merit.
Re: Cam lobe damage
Reply #1 on:
November 08, 2015, 08:25:20 PM »
Nope, need to send it back to mfg for regrind, or shelve it. It will only get worse, and take out the next lifter you put on it very quickly. When a roller lifter lets go, bad things happen all over the bottom end. BTDT. Joe-JDC
Re: Cam lobe damage
Reply #2 on:
November 08, 2015, 08:57:42 PM »
Looks too deep to scuff. What happened?
Last Edit: November 08, 2015, 09:09:13 PM by Nightmist66
Re: Cam lobe damage
Reply #3 on:
November 08, 2015, 11:05:00 PM »
A roller axle failed and came partially out of a comp cams roller lifter. I have also had comp cams full skirt lifters crack or break, lucky not in a critical place but it's never good having pieces laying around in the engine. I switched to crane lifters about 5 years ago that only has the partial skirt were the link bar goes and haven't had a problem since. I have never ran the morel lifters before but most of the guys here seem to use them so that will be my next set.
Re: Cam lobe damage
Reply #4 on:
November 08, 2015, 11:10:37 PM »
Thanks Joe. I was hoping to make a couple bucks, I'll pass the info on to the prospective buyer though. Maybe I can make a mailbox post out of it.. oh well.
Re: Cam lobe damage
Reply #5 on:
November 09, 2015, 05:32:47 AM »
I wonder if the cracked cam thrust plate was caused when the lifter went astray, jamming the cam's nose into the plate. Agree that that lobe needs manufacturer help in a big way.
FE Technical Forum
Cam lobe damage
