Author Topic: Gear vendors od  (Read 9772 times)
Gear vendors od
« on: October 28, 2015, 07:01:49 AM »
Any one with a GV OD in a 64 Galaxie
Did you have to cut the floor ?
Re: Gear vendors od
« Reply #1 on: October 28, 2015, 07:43:06 AM »
I have one is a 63.5 Galaxie, so same basic setup.
I did not cut anything, tho it would be easier if I did.  I probably would have cut the floor just so I had plenty of room, but I'd JUST done a floor R&R with carpet etc and didn't want to tear it out again.  Of course my main mistake in setup, is I'm running a 429 engine which sits too high.  This makes for imperfect driveline angles, but otherwise functions decently.
I'll soon remedy this with an FE engine.
Here is a rear end/GV build thread on my car:
http://www.fordmuscleforums.com/makin-progress/553305-2013-progress-my-63-5-galaxie.html
As you can see in the thread above, I got tired of fussing with the crossmember and just went ahead and built my own.
Re: Gear vendors od
« Reply #2 on: October 28, 2015, 01:56:59 PM »
You say you have a 429 mounted to High
So with an fe corectly mounted there Will
Be even more space maby?? I dont want
To cut or hammer the floor on this car
With a TKO i have to cut
Jay in your64 you have a C4?with a GV OD
IF My memory is corect
Did you cut anything?
The topploader and the C4 is the same lenght
As i remember it
Re: Gear vendors od
« Reply #3 on: October 28, 2015, 04:05:17 PM »
That is what I'm saying Heo...
Due to the engine sitting high, I need to raise the GV to keep a perfect driveline angle.  I'd think with the engine lower it would be much easier.  I've just lived with an imperfect angle until I put an FE in the car.
No I didn't cut anything (if you click the link it shows what I did and didn't have to do for this project).
mlcraven
Re: Gear vendors od
« Reply #4 on: October 28, 2015, 05:11:56 PM »
Read your fordmuscleforums thread from beginning to end...very informative.  I would v much like to have much more aggressive rear gearing to replace the AC-mandated 3.00:1 28-spline unit currently in the Cyclone, but the total cost of rear end upgrade + GV purchase is a significant deterrent.  I don't seem to have much luck finding affordable used units so, if it happens, am resigned to the brand-new route -- which won't be anytime soon.
Anyway, thanks for sharing your experience.
Michael
Re: Gear vendors od
« Reply #5 on: October 28, 2015, 06:10:16 PM »
Mike, scour your local junkyards for Fleetwood RV's built in the late 80's early 90's.  If they have a 460 and c6, they came with a GV.  Good luck....  and yeah, 4.30:1 rear gears was easily the BEST upgrade I've made to the car.
Re: Gear vendors od
« Reply #6 on: October 29, 2015, 04:16:36 AM »
Yes Drew i saw the link you just hammered
The floor
The GV looks like a Volvo Turbo OD ???
Maby i should go junkyard shopping ...
Re: Gear vendors od
« Reply #7 on: October 29, 2015, 06:23:44 AM »
I hammered the floor a little, it honestly didn't make a difference as I was unwilling to hit it hard enough to really force it up.  Was more just to gain an extra 1/4 inch.
Yes, the Gear Vendors is a remade Laycock De Normanville overdrive from behind a Volvo.
Those are smaller type J units.  The GV we run now is a Type P, which is considerably heavier duty.
I've known people to hunt down the older units, but I've also heard of them breaking behind fairly stock engines.
If ya wanna play, ya gotta pay, I'd buy a new one for another vehicle without hesitation.
AlanCasida
Re: Gear vendors od
« Reply #8 on: October 29, 2015, 10:09:32 AM »
"Of course my main mistake in setup, is I'm running a 429 engine which sits too high.  This makes for imperfect driveline angles, but otherwise functions decently."
Hey Drew, if you get a Milodon Street pan for your 460 you can lower the motor quite a bit. Instead of the rear of the pan sloping down to the sump. it is chopped more squarely. It worked well on my 66 Galaxie anyway. I don't know what that will do with your mounts, headers etc. I did not use a kit when I put the 521 in my car, I made my frame mounts(used 66 Galaxie FE insulators) and used '75 Torino 460 headers.  I am running a C6/GV also.
Re: Gear vendors od
« Reply #9 on: October 29, 2015, 11:02:42 AM »
Yeah, Alan, if I had decided to keep the engine I would have done that.  I remember you had a fantastic post showing the oil pans etc.  For whatever reason, I just needed to build an FE for the ole Gal, so it doesn't matter at this point.
I love the 429, it is a fantastic engine, but fitment wise and for originality sake it just wasn't working in the car.  I'll most likely stick it in my truck, it'll do just fine there :P
Re: Gear vendors od
« Reply #10 on: October 29, 2015, 12:29:19 PM »
I did have to cut the floor to make the GV overdrive fit in my 64 Galaxie, and get the driveshaft angle right.  Its funny that on my Mustangs, no surgery on the floor was necessary, but on the 64 Galaxie it was.
Re: Gear vendors od
« Reply #11 on: October 29, 2015, 01:51:33 PM »
Yes the Mustangs and fairlanes have
More room in the tunel Than the
Galaxie strangely enough ??
Maby they need higher tunel beacuse
They are Unibody
Re: Gear vendors od
« Reply #12 on: October 29, 2015, 02:05:26 PM »
Just as an FYI, I did ask the Gear Vendors reps while I was at Dragweek if they had parts & repair services for the Laycock OD's and they said they did for most, some would need updating on certain components.
Re: Gear vendors od
« Reply #13 on: October 29, 2015, 02:44:28 PM »
how much RPM drop do you guy's get with the Gear vendors ??
Re: Gear vendors od
« Reply #14 on: October 29, 2015, 04:18:04 PM »
They are 0.78-1 i think so 22percent
Drop. 220 Rpm per thousand Rpm
