Author Topic: 67 & 68 Mustang and FE Parts for sale  (Read 4892 times)
Bolted to Floor
« on: August 23, 2015, 12:02:35 PM »
Cost of part + actual shipping cost. If you see something you like but not the price, shoot me an email with a reasonable offer.
D2TE AA Heads. $200.00 Date codes 5L4 and 5L21. Exhaust is drilled for Cobra Jet pattern. Stock size intake and exhaust valves. They were gone through by A Guaranteed motors in Houston as part of a long block rebuild about 8 years ago, they have never been ran. They will need to be disassembled and cleaned. SOLD
Lincoln Versailles Disc Brake 9 Inch Rear End. No center section, all other parts are there. It's been under a non-running car for the last 20 years, will need some TLC. This housing is the same dimension as the 65/66 Mustang. $325.00 or best offer. Not really interested in shipping this SOLD
Headers, Fits 67 & 68 Mustang with 390 / 428 motor. They were installed in my 67 with a 4 speed transmission. No power steering or power brakes. They have a few dents and dings for clearance.  No tags or markings to determine manufacturer. One bolt hole looks bad cause the bolt was removed with a cutting torch. $100.00 SOLD
Clutch disk Centerforce #281226, New in box never used. 11", input shaft spline 1-1/16"-10. Was bought for 67 Mustang with 390. Will fit other Fords. $75.00 Follow link to Centerforce site.  http://www.centerforce.com/products/product-detail/id/CTF-281226/name/centerforce-i-ii-clutch-disc
Flowmaster Series 40 Mufflers Part #43041 Offset in and center out, 3" steel. $50.00 for the pair. Been in the rafters of my garage for years. SOLD
DynoMax Super Turbo Mufflers Part # 17731 for 2-1/4" pipe with offset in and center out. One of them has some dents on the end from removal. $40.00 for the pair.
Inner Cowl vent repair panels for 67 Mustang $25.00 each or $40 for both.
67/68 Hood Louvers with air scoop grill intact $50.00 for the pair.
1968 Mustang Quarter Panel Reflector Bezel $10.00 for the pair
68 Grill Outer Molding, Ornament Corral, and Running Pony Ornament $60.00 for all three pieces. They need to be cleaned up.
Power steering pump bracket from a late 70's full size car. Part # D8AE 3A732-AA $10.00
There are pictures at:
http://s1068.photobucket.com/user/jpdixon6/library/?sort=2&page=1#/user/jpdixon6/library/?sort=2&page=1&_suid=139855603712209224513333850106
If the pictures are still there, I still have the parts.
« Last Edit: January 16, 2016, 05:20:37 PM by Bolted to Floor »
fastback 427
Re: 67 & 68 Mustang and FE Parts for sale
« Reply #1 on: August 23, 2015, 11:30:46 PM »
I'll take the headers for an upcoming project. I'll send you a message, thanks, Jaime.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
Bolted to Floor
« Reply #2 on: August 24, 2015, 09:21:55 PM »
Thanks Jaime, Sent a PM back.
