FE Technical Forum
Hydraulic roller lifters
Topic: Hydraulic roller lifters (Read 4746 times)
bn69stang
August 04, 2015, 07:41:30 PM »
Getting ready to start my fe make over , and have a question on the lifters . Do i need to soak them in oil before assembly ? , this my first roller cam .. Bud
69 mach 1 , 428 C J Blue Oval Performance BBM heads -T@D rocker s- Blue thunder intake - Comp hydr roller - MSD ignition - FPA headers- Holley 850 hp double pumper - TKO 600 - 9 inch 3.89 Detroit Locker . ride tech coil over conversion - power rack @ pinoin steering - 13 inch drilled @ slotted 4 wheel disc brakes ..
Re: Hydraulic roller lifters
Reply #1 on:
August 07, 2015, 08:30:59 AM »
I don't. They get washed and oiled before they go in the bores, but I don't soak.
Instagram: brentlykinsmotorsports
YouTube: Lykins Motorsports
philminotti
Full Member
Reply #2 on:
August 07, 2015, 05:33:43 PM »
I soaked my Crane lifters in oil overnight when I built my first motor. Don't ask me why because I have no idea. Unbeknownst to me, they filled with oil. After I installed them AND the intake and attempted to set the preload, I realized I was opening the valve and not compressing the lifter plunger. Had to pull the intake and bleed all the lifters by hand. Don't soak.
Last Edit: August 07, 2015, 05:36:20 PM by philminotti
Reply #3 on:
August 07, 2015, 06:29:16 PM »
Usually when they do that, you can roll the motor over slowly and the lifters will bleed out.
bn69stang
Reply #4 on:
August 07, 2015, 06:57:38 PM »
Ok thanks for the feed back guys , im at the back of the car now and working my way forward and try ng to keep all my bases covered , but making major changes to the stang for sure ,, Bud
FE Technical Forum
