Author Topic: 428 crank  (Read 12826 times)
FirstEliminator
428 crank
« on: July 08, 2015, 08:22:14 PM »
   Hey guys,
    My 68 Colony Park is a 428 car. The flex plate is missing a tooth so I pulled the trans. Of course I had to open to trans and found 3 clutch- drums for both forward and direct. I upgraded to fit 4 clutches in each pack. Plus put in a wide band. also, I put in E4OD front plant to make the C-6 wide ratio.
    Anyway, I was just getting ready to put the new flex plate on and noticed it has a balance weight. So, my question is:  Are all 428 externally balanced? Or, is it only the 428 CJ?
   If all 428 are external balanced, I have the feeling someone robbed the 428 and put in a 390 sometime in the past.
   Since it was obviously running without vibration using a neutral balance flexplate, I am going to take one off my 390 that's on a stand to get this together tonight.
    It will be disheartening to find that might not be a 428.
   Thanks,
      Mark
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
Re: 428 crank
« Reply #1 on: July 08, 2015, 08:40:10 PM »
You can always do a stroke check.
A small stick/rod down the spark plug hole to measure at TDC and BDC
and anything close to 4" is your 428 and close to 3 3/4" is 390.
Re: 428 crank
« Reply #2 on: July 08, 2015, 08:47:34 PM »
All 428s are externally balanced.  However, if they have been rebuilt at some point, Mallory metal could have been added to the crank to make the external balancing unnecessary.  Check the stroke like Howie says and you will find out what you've got.  If it is a 428, and it was running without any vibration with the neutral balance flywheel, I'd put a neutral balance flywheel back on.
FirstEliminator
Re: 428 crank
« Reply #3 on: July 08, 2015, 09:17:04 PM »
    That just about guarantees that it's not a 428.  Someday I will check the stroke to verify. At this point I suppose it doesn't matter. Just another aspect of getting F'd when buying an old car.
    thanks for the info,
        Mark
Mark
68 Monterey 390 C-6
Re: 428 crank
« Reply #4 on: July 09, 2015, 09:05:04 AM »
Mark, I would really think about checking the stroke with a welding rod or dowel down the spark plug hole before getting a new engine.  It is possible that the engine is still a 428, and someone put on a 390 flywheel.  If you don't run the engine at high RPM, its probably not going to vibrate with that 390 flywheel.  The only way to know for sure is to check the stroke - Jay
Re: 428 crank
« Reply #5 on: July 09, 2015, 09:15:31 AM »
I've done that test on the dyno (not on purpose... :-[ ) and they shake pretty good....
Re: 428 crank
« Reply #6 on: July 09, 2015, 09:16:54 AM »
Believe me, a stock 428 engine WILL shake with a 390 flexplate installed!  I have experienced it, and it is unmistakable.  It starts almost off idle and just gets worse the more rpm you go.  You either have a different shortblock, or it has been neutral balanced like Jay said.  Joe-JDC
Re: 428 crank
« Reply #7 on: July 09, 2015, 10:25:16 AM »
Thanks for the info guys, I guess I'm surprised they shake at lower RPM - Jay
Re: 428 crank
« Reply #8 on: July 09, 2015, 10:51:57 AM »
Mark, When you had the flexplate off did you happen to notice if the back of the block had a "scratch" mark? Usually an "A" or "C" on most 428's. Have you looked at the date code on the block? If the engine was replaced it may not be a date that makes sense for the production of the car. In '68 ( and later ) most engines received a partial VIN stamped on either the back of the block or on one of the cylinder heads. It may not be easily visible but worth a look if you still have the transmission out and can look through the transmission tunnel, might help determine if you still have the original engine.
FirstEliminator
Re: 428 crank
« Reply #9 on: July 09, 2015, 12:15:30 PM »
   The date code was pretty rough to read. It did start with a 6. So we know the engine has been replaced at some point in the life of the car with an engine that is a couple years earlier. Probably a 390. Could be a 410 or a 352.
  I don't recall seeing any particular markings on the rear of the crank.
   The trans is in and I drove the car last night.
     I'll accumulate a 428 to make things right. Eventually this car will be getting a full restoration. It's a pretty well optioned car and quite deserving of preservation.
   thanks,
    Mark
Mark
68 Monterey 390 C-6
Re: 428 crank
« Reply #10 on: July 09, 2015, 01:52:38 PM »
Kevin was talking about the back of the block itself Mark.
If it had a mark like this (or an A, could be unreadable also) then you would prolly have a 428.
I have a good friend that just bought a Q wagon and found it was a 390 replacement.
57 lima bean
Re: 428 crank
« Reply #11 on: July 09, 2015, 02:35:03 PM »
"Could be a 410 or a 352"...These have different flex plates.The 410 would have the external weight as the 428.
FirstEliminator
Re: 428 crank
« Reply #12 on: July 09, 2015, 05:51:28 PM »
   I was noticing the back of the block had paint on it. I didn't notice anything that looked like that deflated C.
   410 has external balance?---well, 352 or 390-----probably a 390.
Mark
68 Monterey 390 C-6
FirstEliminator
Re: 428 crank
« Reply #13 on: August 05, 2015, 11:03:43 AM »
   Hey guys,
   So I've been looking around for a 428. The other night I had put an ad on Craigslist for WTB: Ford 428.  I walked into work this morning to find a message on my answering machine that a guy had a 428. Surprisingly, he only lives 2 towns away. The heads are still on the engine. So I can't measure the bore. I know to look for the external balance weight---but it could still be a 410.  What are the defining features to tell the difference between a 428 and a 410?
   thanks,
     Mark
Mark
68 Monterey 390 C-6
Re: 428 crank
« Reply #14 on: August 05, 2015, 01:15:55 PM »
It sure would have been nice if Ford would have just cast a big "428" on the outside of the block, but they didn't. My first bit of advice would be to check out 428cobrajet.org - best place by far for info on these motors. Here's a link right to the engine block I.D. section, but the whole site is a good read.
http://www.428cobrajet.org/id-block
It's pretty much impossible to I.D. a 428 from the side or front of the block, best clue is either the "A" or "C" scratch mark on the back of the block like the picture Marc posted. Since the 410 is just a 390 block with the 428 crank they most likely won't have a "A" or "C" scratch mark. If the seller will remove the core plugs you MIGHT find a cast "428" on the bottom of the water jacket, but it could be on one side and not on the other, or could be in the front or rear ( only visible with a head off ). One of those newfangled video bore scopes could be helpful.
