Author Topic: C4ae-g heads  (Read 10027 times)
matt souders
C4ae-g heads
« on: July 04, 2015, 06:46:22 PM »
Just thought I'd post a couple pics and get a few opinions of a little port work. I cc'd the heads prior to grinding on them. They where 142 which I thought they where supposed to be around 150 which after porting (minus a little blending left to do) they measured at 153cc's. I guess I was wondering if anyone cc'd these heads before and after mild porting. I just tried to straighten the sides, raised the roof slightly and a little pocket porting. I left the short side alone except a little clean up of the casting flash.
Re: C4ae-g heads
« Reply #1 on: July 05, 2015, 05:16:53 AM »
I'm by no means a head porting guy, but they look good to me.
Iron is tough, it takes some time to do all 16 holes. :P
amdscooter
Re: C4ae-g heads
« Reply #2 on: July 05, 2015, 11:22:27 AM »
^^^ No joke, he's got some time in there.  ;) End product looks great.
matt souders
Re: C4ae-g heads
« Reply #3 on: July 05, 2015, 04:39:03 PM »
Thanks guys. I haven't kept track of time but probably have 2-3 hours in each intake port. Just starting the exhaust side. Haven't figured out how I'm gonna attack them yet. I guess no one has measured these ports before and after porting. Im just curious that's all.
KMcCullah
Re: C4ae-g heads
« Reply #4 on: July 06, 2015, 01:45:05 PM »
Looks like you improved the flow but didn't go nuts enlarging your cross section. Should work good on a 390. It always get hung up on the "more is better" idea and ultimately screw everything up.  ::) Are you keeping the stock size valves?
I started down this road a few years ago and then changed my mind after I talked to Les Schmader. He only wanted $525 to port my C4-G heads and add bigger valves. I sent him the valves of course but for that kind of $$$ it was a no brainer for me.
http://fepower.net/simplemachinesforum/index.php?topic=620.15
Kevin McCullah
BH107
Re: C4ae-g heads
« Reply #5 on: July 06, 2015, 03:23:03 PM »
Looks real nice, but the real story will be when you get them on a flow bench and see how well they flow, and if they stayed quiet.
Keep us updated.
matt souders
Re: C4ae-g heads
« Reply #6 on: July 07, 2015, 02:34:37 AM »
Valves are going to be cj size and I hope to get them on a flow bench soon. There going on a 390 with a 294s. Cam and a street master intake which I have a crazy off the wall idea for as well. 525$ plus valves sounds like a hell of a price knowing what time goes into this. Granted i didn't use carbide burrs Very much, to be cautious. I'm hoping to get flow in the 240 range by 400" of lift.
« Last Edit: July 07, 2015, 03:23:29 AM by matt souders »
