Author Topic: 16 Hole pattern for CJ Exhaust  (Read 4871 times)
jimeast
« on: June 05, 2015, 04:16:43 PM »
I have a set of C6AE-R heads with eight exhaust flange bolts.  I would like to drill for a 16 bolt CJ exhaust pattern.  Does anyone have a drawing or a sketch showing the bolt hole pattern with dimensions?
Phil Brown
Re: 16 Hole pattern for CJ Exhaust
« Reply #1 on: June 05, 2015, 05:10:46 PM »
Don't have the hole layout handy. But watch the depth when you drill and tap the lower holes, might find water down there :-)
« Reply #2 on: June 05, 2015, 07:43:46 PM »
Take your CJ exhaust manifolds and lay them on the head, and install any bolts that fit, then take a center punch and centerpunch the other holes.  Drill and tap from your centerpunch location.  You will need a real center punch, not an awl to get the holes perfectly centered with the manifolds.  Joe-JDC
Dryhoze1
  • Fe
« Reply #3 on: June 05, 2015, 10:11:43 PM »
Use a transfer punch in the method stated above.
Sponsored by nobody.
427Fastback
« Reply #4 on: June 05, 2015, 10:44:16 PM »
The last 2 replies are exactly how I do it....Manifold for the template and transfer punches for the hole location....
1936 Diamond T 212BD
1990 Grizzly pick-up
