Author Topic: 61 390\375hp engine  (Read 12094 times)
sanddoc
61 390\375hp engine
« on: January 21, 2015, 11:36:49 PM »
does anyone have the technical specs of this engine?
 intake, springs, valve size, lift. etc:
thanks
Dave
RJP
Re: 61 390\375hp engine
« Reply #1 on: January 22, 2015, 12:22:59 AM »
thanks
Dave
Intake: 1 x 4V alum. dual plane. [Very minor diff between the 352-360 HP manifold] Springs: single spring with damper,  pressures: [checked without damper] 80-90 seat @1.82"/184-194 @ 1.32", Cam: .479" lift-276 deg. duration, lashed at .025"  Valve size: intake 2.03" ex. 1.56" same as stock 300 HP. Need anything else?
« Reply #2 on: January 22, 2015, 01:28:10 AM »
I'll add to that a little, there was actually quite a bit that came with the package. Both the '60 & '61 HP used a solid lifter camshaft. The cast iron "shorty" headers started with the '60 352 / 360hp and continued on the '61 390 HP. Jay's dyno testing showed a substantial increase in power with those over the flat manifolds. And although visually the '60 352 HP aluminum intake and the '61 390 HP look similar, Jay's testing also saw a significant improvement there too. The garden variety FE came with an Autolite carb ( an excellent carb ) but both HP's came with a slightly larger Holley. In '60 the HP came with high compression heads with a better combustion chamber, I'm not sure about the '61 version.
troublemaker427
« Reply #3 on: January 22, 2015, 09:07:16 AM »
To add to this the '60 352-360 and '61 390-375/401 both use the C0AE-6090D heads.  Both engines also used the same spec cam.  The '60 used a 540cfm Holley and the '61 390-375 used a 600cfm Holley.  The advertised CR is 10.6-1.
Head Specs,
In port 2.34 x 1.34
Ex port 1.84 x 1.28
59.7cc
I'm currently gathering parts to build either a '61 390-375 or 401.  I have both intakes and the correct carburetors.  This engine will go in my '61 Fairlane that I am currently restoring.  My plan is to build this car basically like it was 1961 and see how fast it will go...
« Last Edit: January 22, 2015, 09:13:20 AM by troublemaker427 »
MeanGene
« Reply #4 on: January 22, 2015, 04:34:55 PM »
I still have my 61 HotRod Yearbook that my dad bought, it has the old-style breakdowns of the engines laid out in pieces and extensive spec articles, 390/375 and 401, 409 Chebbie, and IIRC the 389 Poncho
RoyceP
« Reply #5 on: January 25, 2015, 10:00:50 AM »
The COAE 6090-D cylinder heads are the most special part of the 375 HP 390 engine. A friend of mine massaged a pair for a 427 stroker motor. Chamber size is the smallest of any FE head that Ford ever made. These are 2.15 / 1.66" valves:
W code 427 Cougar GT-E Augusta Green / Saddle XR-7
R code 428CJ Cougar Red / Black XR-7
