FE Technical Forum
fe main girdle
Topic: fe main girdle (Read 13436 times)
fastback 427
Sr. Member
fe main girdle
September 28, 2014, 01:50:25 AM »
I was wondering if anyone was running a main girdle on their fe. I saw one listed on eBay that looked like a good value for what you get. Description says minor machining to the caps is required and line hone is recommended. Would the pan rail need to be machined flat as well? Seems like it would keep the caps from moving around. Its probably not as strong as cross bolting but should be easier and cheaper.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
faulkdaddy
Re: fe main girdle
Reply #1 on:
September 28, 2014, 08:53:56 AM »
Yes, I run the one from Tim Oelerich. I have it coupled with crossbolts. Before the crossbolting I used just the girdle. Since it was already on the block I had my machinist setup the Pro-Gram caps and continue using the girdle also. Getting ready for another for a Centerolier block with billet caps as well. Very nice sturdy piece with alot thought put into it.
Bruce Faulkner
SSG U.S. ARMY (RET)
BH107
Sr. Member
Re: fe main girdle
Reply #2 on:
September 28, 2014, 12:30:55 PM »
My 432 stroker has one because the block came with it. Barry has posted on the other forum that the rails do need to be squared as well, and that by the time you are done with all of the machining you could have crossbolted the block. Still, there are a lot of guys that swear by it without touching the rails, and I'm surely not going to remove it from my block that is already done.
Qikbbstang
Re: fe main girdle
Reply #3 on:
October 02, 2014, 07:43:46 PM »
I believe Barry R provided the details of installing a girdle. What looks easy is very time consuming, requires detailed machine work and ends up very costly.
Re: fe main girdle
Reply #4 on:
October 03, 2014, 07:27:35 PM »
Here's a link that includes Barry's thoughts.
http://www.network54.com/Forum/74182/thread/1370615194/FE+MAIN+SUPPORT-
paulie
fastback 427
Sr. Member
Re: fe main girdle
Reply #5 on:
October 03, 2014, 11:10:02 PM »
Thanks for the input and the link guys. After reading what Barry and Blair had to say, seems like there would be about a grand in machining. That and the cost of the girdle would go a long way to one of those new bbm blocks.
Jaime
top end toploader
Re: fe main girdle
Reply #6 on:
October 04, 2014, 06:14:56 AM »
Here's a link to a current Ebay auction for the girdle. Just FYI.
http://www.ebay.com/itm/Ford-FE-Deluxe-Main-Girdle-352-360-390-406-410-427-428-Cobra-Jet-cammer-shelby/261607919944?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D25879%26meid%3Dc7d379b691cb4a01876aaef481c379ab%26pid%3D100011%26prg%3D10819%26rk%3D1%26rkt%3D10%26sd%3D261226229661
paulie
bn69stang
Re: fe main girdle
Reply #7 on:
October 04, 2014, 09:26:34 AM »
I agree , put the money towards a new block and the BBM blocks are very nice , Iron and aluminum both , i got to look at both up close when i picked up my heads from Rob at blue oval performance , I want to get the aluminum one myself ..Bud
69 mach 1 , 428 C J Blue Oval Performance BBM heads -T@D rocker s- Blue thunder intake - Comp hydr roller - MSD ignition - FPA headers- Holley 850 hp double pumper - TKO 600 - 9 inch 3.89 Detroit Locker . ride tech coil over conversion - power rack @ pinoin steering - 13 inch drilled @ slotted 4 wheel disc brakes ..
mike_burch
Newbie
Re: fe main girdle
Reply #8 on:
October 06, 2014, 01:20:13 PM »
I keep thinking of Shoe and the Capsaddle... You guys remember him? I think it was he that came up with that...
mike_burch
Newbie
Re: fe main girdle
Reply #9 on:
October 06, 2014, 05:34:48 PM »
A thread about the capsaddle, and some pictures...
http://www.network54.com/Forum/74182/thread/1304370162/Here%27s+what+a+Capsaddle+looks+like
FE Technical Forum
fe main girdle
