Author Topic: Trunk full of Monkeys tour 2014 - Thursday  (Read 13226 times)
« on: September 13, 2014, 08:50:23 AM »
Just a quick post before heading to the track, and I'm still having some issues with pictures. I'm taking them, I'll just have to come back and add them in later. The weather front went through and it turned much cooler in Great Bend ( as predicted ). We went through the usual routine and Joel went up for his pass - 13.88. Much quicker than anywhere else. But Joel said it was missing on the top 3rd and 4th gears ( he's not getting into 5th in the quarter ). Nothing obvious stood out as the cause. We fiqured either fuel or ignition related. He made another pass - 13.85, but again with the same issue. MPH is also down about 10 MPH. My quess was that the air was maybe that much better and now it was lean, or maybe now not able to use the couple degrees more timing we had added earlier in the week. Joel has an air-fuel meter but it's on the floor. He decided to try and mount it somewhere he can see it down track tomorrow. Lots of drama in the last 15 minutes at the track in Unlimited, I won't detail that, you can probably get more info online. We took off for Tulsa and had a smooth trip there. All that's left is to make it to the track from the hotel one more time.
« Last Edit: September 23, 2014, 11:50:31 AM by thatdarncat »
Re: Trunk full of Monkeys tour 2014 - Thursday
« Reply #1 on: September 23, 2014, 11:39:47 AM »
Finally having a little luck with Photobucket. Here's a sample of the fans who turn out at the checkpoints to check out the action. This was across the street from the mural we needed to get a picture of.
People bring out their hot rods, one of the Ford faithful. Nice Mustang
And here's Joel on his burnout the day before at Thunder Valley in Okla.
« Reply #2 on: September 23, 2014, 08:23:30 PM »
You guys left the tracks long after we did so you got to see more cool stuff along the way. We saw just a few greeters in the towns because we went through them before most of the pack.
The Old Smobile runs pretty decent , not a bad ride to take.
