Author Topic: The Road to Drag Week 2014 - July 27  (Read 54156 times)
R-WEST
Re: The Road to Drag Week 2014 - July 27
« Reply #30 on: July 30, 2014, 11:03:30 PM »
Fascinating stuff.
Way over my head, but fascinating!!   8)
« Reply #31 on: August 03, 2014, 04:43:50 PM »
I've heard it suggested that a pair of rear seals facing in both directions is a good idea with a dry sump. It'd probably take some block machining and special-ordered seals but it would likely help against the possibility of leaks.
68Rcodeman
« Reply #32 on: August 03, 2014, 05:39:20 PM »
Jay, Im sure you know that there is an oil dye to add and a blacklight will show you a bright green trace of where the leak starts. It is a great tool that is used at work at Ford. In fact the manufacture installs the dye in the engines , Trans , and even the A.C. has installed while assembled new.
        David
« Reply #33 on: August 03, 2014, 07:59:54 PM »
Yep, I do know about that, and in fact I used some this weekend...
fe66comet
« Reply #34 on: August 03, 2014, 08:26:15 PM »
Yup got some on the shelf. I like the red dye, when you get oil sprayed everywhere it looks like a cat got stuck in the fan LOL.
