Author Topic: newbie help with 68 Monterey  (Read 4069 times)
GTXtreme19
« on: June 24, 2014, 12:13:42 PM »
Hi fellas and ladies,
I just bought a 68 Monterey 390 car for $800 (its not in my possession yet, don't want to drive 30 miles with a bad exhaust, and carb puking fuel.) Anyway back to the point, the passenger side exhaust manifold is cracked in 4-5 places. As much as I'd love to put some beefy headers on it I don't have the $500 to spend on them right now. So what are my options for the factory manifold? Will other vehicle manifolds fit it? What should I be looking for.
And for you picture whores
Re: newbie help with 68 Monterey
« Reply #1 on: June 24, 2014, 12:26:54 PM »
Hi
You could probably use them from
all Galaxies and Ltd,s with FE,s 65-
71I think
JamesonRacing
« Reply #2 on: June 24, 2014, 04:21:36 PM »
Finding a replacement manifold shouldn't be that difficult, but getting the old one off could be a pain.  Expect that at least a couple of the top bolts with break off and need to be drilled out and retapped.  The face of the exhaust flange may be eroded and may not seal well.  I hate working on old rusty exhaust!
GTXtreme19
« Reply #3 on: June 25, 2014, 12:00:23 AM »
Thanks for the heads up fellas. I'll keep my eyes peeled. As far as the rust issue I've found a good spray of atf and acetone 1:1 mix works quite well on freeing up seized rusty bolts. My biggest concern is another area of the exhaust cracking when I remove the manifold
