Author Topic: 3/4 Race Cam  (Read 6637 times)
3/4 Race Cam
« on: October 29, 2011, 06:28:45 AM »
Thinking Bigger and a bit of humour. ::)
Car: 1968 Mustang Fastback
Eng: 427 Genesis 482 ci Victor intake with a 150 shot.
Trans: C6 with 10", but most likely needs to be looser though.
Rear gear: What ever it needs.
Useage: Street, Strip, Hardware store run, wherever I need to go. It's my car.
Based on Lunati's newest computer designed cam profiles, this series of Solid Roller Tappet camshafts are designed specifically for drag race applications where mid to high RPM performance and round after round consistency is most critical.
Solid roller, rough Idle. Good cam for bracket racing applications with 390-428 cubic inch motors with aftermarket performance heads. Needs 4000-4500 RPM stall converter, headers, 11:1 compression ratio or better and 4.56 gearing or better.
Advertised Duration (Int/Exh): 302/310
Gross Valve Lift (Int/Exh): .751/.751
LSA: 108
RPM Range: 4500-8000
Includes: Cam Only
Part Number: 505A1LUN
http://www.lunatipower.com/Product.aspx?id=2265&gid=253
Re: 3/4 Race Cam
« Reply #1 on: October 29, 2011, 08:50:58 AM »
I see:
Shifting at 7500-ish rpm if you have good heads, especially with the nitrous.
The lobe separation is tight if you want it to be a "nitrous cam".
JMO,
paulie
Lobe Seperation
« Reply #2 on: October 29, 2011, 11:04:22 AM »
I have thought a lot about this.
I want a N/A engine that I spray once in a while.
To use a wide separation for a once in a while shot may not be the best plan.
It is a small flick when compared to the size of the ci. It's not like I'm dumping buckets of the
juice into it.
The engine is primarily a MAX power for my bracket car.
And if buddy ever sells me his original C8 Tunnel Wedge
then the cam should work good with that intake.
I want to spin into the mid 7k's so I don't have a problem with that.
Re: 3/4 Race Cam
« Reply #3 on: October 29, 2011, 04:55:43 PM »
Well I think you're on the right track then.   I just got the 3/4 race cam joke.   ::)  ;D
A 4.56 rear gear will get you around 135 mph at about 7400 rpm with 28 inch tires.
paulie
