Author Topic: WTB factory fe intake  (Read 18824 times)
Hubble63
« on: February 08, 2014, 11:55:56 AM »
looking for a factory alum medium intake  to put  on 428 mud bogger
Hubble63
Re: WTB factory fe intake
« Reply #1 on: February 09, 2014, 06:04:58 PM »
 :'(  all the people out there and no one has a intake im looking for
« Reply #2 on: February 09, 2014, 07:38:31 PM »
4V medium riser intakes are hard to find; I have over 50 FE intakes and I don't have one.  I had to borrow one to test for my book.
Hubble63
« Reply #3 on: February 09, 2014, 08:12:36 PM »
jay where can I get your book then
« Reply #4 on: February 09, 2014, 08:59:36 PM »
The book is available from this site.  Go to this link:
http://www.fepower.net/GFEIC.html
Hubble63
« Reply #5 on: February 09, 2014, 10:38:38 PM »
 :) thanks I will do that for sure
« Reply #6 on: February 09, 2014, 11:53:02 PM »
The factory intakes are expensive if in decent condition also. Is there a reason you won't consider an RPM intake? I wouldn't think a mud bogger would have any requirements for a factory intake. A gasket match and decent blend would give you comparable, if not equal or even better power. Or you could even use an iron CJ intake or Victor depending on the power level you're seeking.
« Reply #7 on: February 10, 2014, 12:15:39 AM »
Might want to widen your search to 428 Police Interceptor versions too, much more common.
Hubble63
« Reply #8 on: February 10, 2014, 08:31:07 AM »
im looking at a police one now . I spent 10 hours on a dual plain edelbrock   and at low end it still struggles.   44 inch tires with 513 gears x 2  . should go better I think . 554 lift   cam lift 320  duration 230 .    coae 6090 d  heads  all on a 428
BH107
« Reply #9 on: February 10, 2014, 11:30:22 AM »
With the early heads I would get a Blue Thunder with LR/CJ ports.
Hubble63
« Reply #10 on: February 10, 2014, 01:36:20 PM »
how much does a blue thunder medium rise intake cost and where do they sell them
BH107
« Reply #11 on: February 10, 2014, 02:40:20 PM »
Survival Motorsports is a distributor for BT.
Where are you located? I have a brand new one on the shelf that I don't "need" right now.
Hubble63
« Reply #12 on: February 10, 2014, 03:44:41 PM »
Wisconsin how much   zip is 54024 can u send pic to web site
Joe-jdc
« Reply #13 on: February 10, 2014, 03:57:05 PM »
Which Edelbrock-Performer 390, or Performer RPM?  A RPM intake will outflow just about any dual plane intake out there with proper porting.  They can be ported to flow in the 400cfm range. About the best a Performer 390 can be ported is 300-305cfm.   Joe-JDC
Hubble63
« Reply #14 on: February 10, 2014, 04:06:02 PM »
performer 390 I took  out as much as I could by using gasket match
