Author Topic: WTB factory fe intake  (Read 18855 times)
Re: WTB factory fe intake
« Reply #15 on: February 10, 2014, 06:18:38 PM »
It takes a LOT to get 44s moving, especially in mud! Even with the 5.13 gears, that's a lot of weight. The Performer 390 is only good for low end performance and low speed torque, so it should perform ok down low (where you say you're having a lack of power) but it would give up quickly. Really not a good intake for any kind of performance engine. Even with the gasket matching, the runners are very small. Maybe you have another issue such as timing but I'm guessing it's just the combo of a mild cam, lots of weight and huge tires.
Hubble63
« Reply #16 on: February 10, 2014, 06:36:58 PM »
truck is only 4000 #   msd dis  and put march pully system on  c6 tranny 4000 stall converter and a 750 edelbrock carb
« Reply #17 on: February 10, 2014, 08:52:55 PM »
By weight, I meant rotational weight of the tires. If you mud bog, then I'm sure you're aware of the big power loss that comes with huge tires. And I meant an initial timing and/or curve issue, not just the distributor. Those are just my opinions, so take that for what it's worth.....which usually ain't much :)
Hubble63
« Reply #18 on: February 10, 2014, 10:34:22 PM »
 :)  what would you set the timming at .   looking at any easy changes I can do to help . what you think about carb im using .
BH107
« Reply #19 on: February 10, 2014, 11:12:01 PM »
Yeah, performer 390 is definitely not the best intake for that... It's starting to max out about when your converter is just starting to lock up. A Performer RPM or BT will definitely work better.
« Reply #20 on: February 11, 2014, 08:49:50 AM »
Try 12-14 degrees initial timing, and +1 on the Performer RPM or the Blue Thunder intake.  With a 4000 stall converter you might even want to go with a good single plane intake like a Holley street dominator, or even a Victor.
Hubble63
« Reply #21 on: February 12, 2014, 02:10:51 PM »
 :)   made up my mind going with blue thunder 428 cj  4v hp intake  will match the heads coae thanks for the great feed back
jungle0758
« Reply #22 on: February 13, 2014, 11:43:31 AM »
There is a early on craigs list in texas in the east texas section off a 1964 Q code GALIXIE,$400.if that helps.it was just re listed it had been on for a while.should be able to buy for $300.let me know how it goes?
Hubble63
« Reply #23 on: February 13, 2014, 01:39:10 PM »
can you give me the address for it on craigs list
Hubble63
« Reply #24 on: February 13, 2014, 04:55:53 PM »
 ;) found the intake is that low or medium rise hard to tell in photo
BH107
« Reply #25 on: February 13, 2014, 07:32:46 PM »
 Early low riser...not the best performing intake.
Hubble63
« Reply #26 on: February 13, 2014, 07:36:13 PM »
talked to the guy he is firm on the price at 400 looks real nice if someone is looking for one
« Reply #27 on: February 13, 2014, 07:41:30 PM »
That is too much money for that intake, IMO.  I bought mine for $250.  Also I agree that it is not the best performing intake; you'd be better off with the Blue Thunder manifold.
Hubble63
« Reply #28 on: February 13, 2014, 11:07:24 PM »
 :) got the blue thunder on the way 428cj
