Author Topic: cam ideas  (Read 19769 times)
c9zx
cam ideas
« on: September 14, 2011, 08:42:44 AM »
I'm looking for suggestions on a solid flat tappet cam. I'm particularly interested in overlap and LCA (LSA) as well as intake valve closing point. Engine is Genesis, 4.25 bore, 4.125 stroke, 6.700 rods, Edelbrock Stage X heads from Barry R, 10:1 CR, pump 91 octane gas, 2500 lb car (fun street car), no vacuum accessories, manual transmission. I've looked at numerous vendor listing and they seem to be all over the place on specs. All input appreciated. Thanks, Chuck
1969 Eliminator G code
CSX-7031 FIA Cobra
2007 Mustang GT, Whipple
1966 Cyclone GT
Re: cam ideas
« Reply #1 on: September 14, 2011, 03:48:53 PM »
Kind of depends on what you want.  If you want to keep it fairly tame, and Comp 292S cam would idle nicely in an engine that size, and give you plenty of power up to 5500 RPM.  Or are you going for a big horsepower number?
Re: cam ideas
« Reply #2 on: September 14, 2011, 06:08:44 PM »
What rear gear ratio are you running?  What rear tire size?  What manual tranny (ratios)?  What max rpm will your valvetrain support and/or what max rpm are you comfortable running?
All that information will help with a suggestion.
paulie
c9zx
Re: cam ideas
« Reply #3 on: September 15, 2011, 08:35:58 AM »
I'd like to see it make peak power about 5800-6000 RPM with max RPM being 6500 RPM. The rear gear is 3.55:1 (light street car) with a Tremec TKO 600, 2.87 1st, .82 OD. I'd like to see it idle at or below 1200 RPM. No particular HP number as a goal but, it seems that 510-520 should be doable. Thanks for the help.  Chuck
CSX-7031 FIA Cobra
1966 Cyclone GT
Re: cam ideas
« Reply #4 on: September 15, 2011, 09:55:31 AM »
Given those constraints I think I'd go with a 306S solid cam from Comp, or something similar.  That cam idled at about 1000 RPM in my 446" 390 stroker, so it should be a little tamer in a bigger cube motor like yours.  You should easily get to the horsepower numbers you are talking about with that cam.
c9zx
Re: cam ideas
« Reply #5 on: September 15, 2011, 02:28:17 PM »
Thanks for the input. Do you think the the 306S is a good match with the currently planned 10:1 CR? Do you feel the Edelbrock stage-X E/I ratios are good enough to run the straight duration and lift cam. Thanks, Chuck
CSX-7031 FIA Cobra
1966 Cyclone GT
Re: cam ideas
« Reply #6 on: September 15, 2011, 04:22:12 PM »
In my opinion I think shorter seat duration would work good with your compression ratio.  Maybe 280-290 degrees.  And I think you could peak at 6000 rpm with somewhere around 252-256 degrees @ 0.050 on the intake.  I think you would want about 4-6 degrees more exhaust duration.   I'd go with a 108 degree lobe separation angle.
I forgot, what intake manifold and carb (or FI) are you running?
c9zx
Re: cam ideas
« Reply #7 on: September 15, 2011, 04:46:14 PM »
Blue Thunder single 4V, 850 or 950 Holley or Quick fuel carb.  Chuck
CSX-7031 FIA Cobra
1966 Cyclone GT
Re: cam ideas
« Reply #8 on: September 15, 2011, 05:55:48 PM »
Hmmmm.  I would suggest a 1" open or cloverleaf spacer under the carb.  I think a Holley 850 would be better than a 950.   You probably know this, but the 850 flows more than a 950.  With your displacement, light weight, and low overall gearing you can use a lot of carb and induction flow.
One thing about the Compcams Magnum solid flat tappets is that the ramps are very slow.  That is not good or bad necessarily.  Slow ramps make it much easier to control the valvetrain without using very high valve spring pressures.  The fact that that the ramps are so slow makes the duration figures a bit misleading compared to modern cam lobe designs.  While a Compcam 306S (with 260 degrees @0.050") sounds huge, it's not as huge as it sounds.  Don't get me wrong, that's a big-ass cam.  But if you get a more more modern, more aggressive cam lobe, it'll have less duration as measured at advertised and at 0.050" lift, yet it will have a similar rpm range and make more power everywhere.  The cost is it will need more spring pressure, and it's life will probably not be as long.
you have a cobra kit car?
paulie
c9zx
Re: cam ideas
« Reply #9 on: September 16, 2011, 07:58:21 AM »
Paulie, The engine is going into a FFR "Cobra". Thanks for the discussion of the ramps. I'm dealing with a fast ramp cam in a 408C right now. Runs very well but, very low vacuum. Thanks, Chuck
CSX-7031 FIA Cobra
1966 Cyclone GT
Re: cam ideas
« Reply #10 on: September 16, 2011, 11:30:12 AM »
You won't get a lot of vacuum out of the 306S either, but I didn't think that vacuum was a concern with no power brakes.  Paulie is also correct about the compression ratio; you should bump it to 11:1, or at least 10.5:1, if you are going with the kind of seat to seat duration that that 306S cam has.  If you don't want to do that, you should back down on the duration somewhat.  But with an engine that big, you will need that much duration to peak in power around 6000 RPM.
Life is full of choices  :D
c9zx
Re: cam ideas
« Reply #11 on: September 16, 2011, 02:18:46 PM »
I didn't mean to confuse things (vacuum) with reference to a different engine for a different car. Thanks for the input on CR needing to be increased to move the peak HP to 6000 or so. You guys are confirming that I'm trying to have a foot in two different worlds with this build, I need to make some adjustments to the "plan". Maybe shorten the stroke to lower the displacement and set CR at 10.5:1 to keep the usable RPM range. Modern pump gas is a real curse. Please keep the advice coming. Clearly I can use the help.  Thanks, Chuck
CSX-7031 FIA Cobra
1966 Cyclone GT
Re: cam ideas
« Reply #12 on: September 16, 2011, 02:31:01 PM »
You can get the best of both worlds, performance-wise by ordering a custom ground cam with much more aggressive ramps.  Less seat duration, similar duration @ 0.050", and more area under the curve.
For instance I have a solid flat tappet Compcam with 270/276 duration @ 0.020", 240/246 duration @ 0.050", and .598"/.608" lift.  It peaked at 6200 rpm with 432 cubic inches.  My heads are little more hogged out than yours, but you get the idea.  The downside is the spring pressure required.   I ended up with about 405 lbs of open pressure.  I used EDM lifters to help lube the cam/lifter interface.  It ran fine for about 5000 miles before I pulled the cam to put in a larger one.  I ran up to 6500-6600 rpm with no problem.   Titanium retainers were a big help avoiding valve float, too.   What I'm getting at is you can have your cake and eat it, too.  It just costs a bit more money and requires a bit more maintenance.
If your combo is the same as mine, but you have 36 more cubic inches, I would guess you'd need about 7-8 more degrees of cam duration get the same peak.  However, since my heads are more heavily ported, I think you'd have to add a few degrees more on top of that.  That's why I say around 252-256 degrees on the intake side could get you there, if you're using an aggressive cam lobe.
If you used the same cam lobes I did, XTQ on the intake and TL on the exhaust, then you might have a XTQ286 on the intake and a TL292 on the exhaust.  That would be 256/262 degrees @ 0.050".  Even though the duration is less than a Magnum 306S it has more area under the curve and will peak higher.  At least I think so.
Or you could move the intensity down a step and usea TL284 on the intake and maybe a HT295on the exhaust.  Thoe are 254/260 degrees @0.50 and would be easier to contol, valvetrain-wise, but still way more agressive than a magnum cam lobe.
The possiblities are almost endless. Just food for thought.
JMO,
paulie
Re: cam ideas
« Reply #13 on: September 17, 2011, 07:46:55 AM »
I had assumed your compression was pretty much set, as if you had already bought your rotating assembly including pistons.  If not that's good.  Though 10:1 compression with a 4.25 bore and 4.125 stroke would require a fairly big dish, I think.
I don't think I'd lower the displacement just to keep the rpm range where you want it.  It'd be better to find a way to bump the rpm's back up with the larger displacement engine.  Up to the point where rpms become problematic.
On the other hand if you're trying to get a Cobra to hook up, more displacement is not necessarily good.
Here's a thought.  Assuming you're still around 468 cubes.  Bump the compression up to 10.5:1.  Mill the heads a few cc.  Use a thinner head gasket if necessary.  zero deck the block if it hasn't been.  Then you could use an off the shelf cam like this Lunati
#30330914
gross lift 616"/.616"
285/295 advertised duration
252/261 degrees @0.050"
110 LSA
Lash.026"/.026"
The exhaust duration is possibly a little longer than necessary, but since your car is so light, your overall gearing quite low, and the cubic inches pretty big, it wouldn't hurt a bit.  And the extra exhaust duration should extend the rpm peak a little.  It might not peak at 6000 but it'll be up there fairly close.
Or bump the compression up to 11:1 and use the Magnum 306S.
Maybe the best question at this point is what is the intended use for your Cobra?  Street? Street/strip?  Road race?  And what parts do you already have?
paulie
c9zx
Re: cam ideas
« Reply #14 on: September 18, 2011, 09:25:10 AM »
The heads, intake, and block are bought, the rest not yet decided on. Thanks for everyones input and help.  Chuck
CSX-7031 FIA Cobra
1966 Cyclone GT
