Author Topic: Spring pressure  (Read 5848 times)
bn69stang
Spring pressure
« on: October 24, 2013, 07:15:26 PM »
How does 130 lbs seat and 340 lbs open on a comp cams extreme energy 274 sound , open to any replies guy s .
rockhouse66
Re: Spring pressure
« Reply #1 on: October 25, 2013, 06:56:47 AM »
Comp's recommended spring is the 924-16 rated 112 @ 1.900 and 355 @ 1.200 so yours are in the ballpark depending on installed height.  Should be OK IMO.
Jim
Re: Spring pressure
« Reply #2 on: October 25, 2013, 07:22:31 AM »
I agree, those springs should be no problem.  If they are duals, take out the inner spring for cam break-in, though...
bn69stang
Re: Spring pressure
« Reply #3 on: October 25, 2013, 03:07:22 PM »
Good deal then thanks for the feed back , i will double check it all when it goes together thanks  Bud ..
manofmerc
Re: Spring pressure
« Reply #4 on: November 04, 2013, 05:53:36 AM »
On my edelbrock headed 427 I am at 145 closed and 380 open .This is lunatis 73121 springs and a lunati solid flat tappet camshaft Your spring pressures should be fine .I run the same spring on my 460 powered dragcar with no issues there either .Doug 8)
bn69stang
Re: Spring pressure
« Reply #5 on: November 11, 2013, 07:00:22 PM »
Thanks guy s for the feed back , doing my homework on comps lifter s and lunati s .. Bud
