FE Technical Forum
Spring pressure
Topic: Spring pressure (Read 5849 times)
bn69stang
Spring pressure
October 24, 2013, 07:15:26 PM »
How does 130 lbs seat and 340 lbs open on a comp cams extreme energy 274 sound , open to any replies guy s .
69 mach 1 , 428 C J Blue Oval Performance BBM heads -T@D rocker s- Blue thunder intake - Comp hydr roller - MSD ignition - FPA headers- Holley 850 hp double pumper - TKO 600 - 9 inch 3.89 Detroit Locker . ride tech coil over conversion - power rack @ pinoin steering - 13 inch drilled @ slotted 4 wheel disc brakes ..
rockhouse66
Sr. Member
Re: Spring pressure
Reply #1 on:
October 25, 2013, 06:56:47 AM »
Comp's recommended spring is the 924-16 rated 112 @ 1.900 and 355 @ 1.200 so yours are in the ballpark depending on installed height. Should be OK IMO.
Jim
Administrator
Re: Spring pressure
Reply #2 on:
October 25, 2013, 07:22:31 AM »
I agree, those springs should be no problem. If they are duals, take out the inner spring for cam break-in, though...
bn69stang
Re: Spring pressure
Reply #3 on:
October 25, 2013, 03:07:22 PM »
Good deal then thanks for the feed back , i will double check it all when it goes together thanks Bud ..
manofmerc
Sr. Member
Re: Spring pressure
Reply #4 on:
November 04, 2013, 05:53:36 AM »
On my edelbrock headed 427 I am at 145 closed and 380 open .This is lunatis 73121 springs and a lunati solid flat tappet camshaft Your spring pressures should be fine .I run the same spring on my 460 powered dragcar with no issues there either .Doug
bn69stang
Re: Spring pressure
Reply #5 on:
November 11, 2013, 07:00:22 PM »
Thanks guy s for the feed back , doing my homework on comps lifter s and lunati s .. Bud
FE Technical Forum
Spring pressure
