Author Topic: 63-64 Galaxie rears  (Read 18251 times)
63-64 Galaxie rears
« on: October 16, 2013, 10:43:06 AM »
Jay,
Do you still have the pictures that are missing from this thread:  http://www.network54.com/Forum/74182/thread/1234198030/Jay+Brown-+Galaxie+Suspension
It would answer a few questions for me.
Redoing the rear end in my car and trying to figure everything out beforehand.  Anyone else with a 63-64 please feel free to chime in, it'll be very helpful.
I doubt I'd need as large a tire as you have, but since I'm doing everything, I might as well massage as much room possible while I have it all apart.
Thanks!
Dp
Re: 63-64 Galaxie rears
« Reply #1 on: October 16, 2013, 11:38:15 AM »
Sure...
« Reply #2 on: October 16, 2013, 03:43:27 PM »
I had 275/60r 15 BFG on 8.5 American racing TT
and it touched on one side(outside) if i had people in the
rear seat
Now i have 255/75 or 70 i dont remember and they
clear with full load hard to get in and out of the Wheel
house though
So with a carefully centered rearend i Think 275 is possible
without cuting anything.
If that is of any help for you
Qikbbstang
Jay, what's the reason(s) for the cable on the front of Cal Trac?
« Reply #3 on: October 18, 2013, 09:19:32 AM »
Limit travel, hold up the bar in the event of catastrophic failure,  sanctioning rules,  piece of mind Or ........?
BTW the small (economy) jack-stands (pictured under the rear) especially at max lift have "surprisingly" little stability. I found out the hard after tipping a car into a garage wall as it fell over - so I'm gun-shy whenever I see them . At least IF you use one a 3-5 Ton stand on the other side the axle (which you might already have there) it adds some stability to the small stand. Small footprint stands are a nightmare waiting to happen. I ended up welding large steel plates under my small footprint stands and pouncing on 3-5 ton stands that are majorly stable whenever I found them priced right
« Reply #4 on: October 18, 2013, 10:49:25 AM »
I dont know in Jays case but i use wires
like that to not perform a pole jump ;D
if the rod end broke
« Reply #5 on: October 18, 2013, 11:58:26 AM »
That is exactly why they are there.  NHRA has started enforcing their use on traction bars like Cal-Tracs, I'm told...
« Reply #6 on: October 18, 2013, 12:28:29 PM »
either way, appreciate the input Jay and Heo.
Just wanted a lil info bookmarked for when I get started on the project.
Re: Jay, what's the reason(s) for the cable on the front of Cal Trac?
« Reply #7 on: October 18, 2013, 12:59:50 PM »
Those are actually 6 ton jackstands, BB, not the small ones.  They are plenty stable - Jay
LuxurySportCoupe
« Reply #8 on: October 19, 2013, 12:20:43 PM »
rear seat
house though
I've got a 275 60 on mine. The rear must have been centered pretty well from the factory though, because they don't rub at all. I'm not going to try, but it almost looks like there is room to fit 295's in there. That's on a 15x8, 4.5 backspace American Racing 200.
1964 Galaxie 390 cruise-o-matic. 445 and C6 coming soon.
« Reply #9 on: October 19, 2013, 01:25:25 PM »
Jay, (or anyone with the monoleafs)
How does the rear end hold up compared to 4-5leaf springs when towing your lil teardrop trailer or with any other load on in the back?
« Reply #10 on: October 19, 2013, 02:23:00 PM »
That is a good looking car.  I definitely need to get my '64 back on the road...
« Reply #11 on: October 19, 2013, 02:25:05 PM »
If I recall correctly Travis at Cal-Trac recommended that you replace the monoleaf springs every 3-4 years, so I would say they don't hold up as well long term.  They don't drag way down under the weight of my little trailer, though.
Randy
« Reply #12 on: November 06, 2013, 11:32:30 AM »
We have L-60 15 under our cars you could do this pretty ease we just ground off about a 1/4 inch on the inner edge and used 8 inch wheels with a 4 1/2 inch inside off set.
« Reply #13 on: November 06, 2013, 01:58:29 PM »
Gezz Randy
What are those L 60's 30 years?
Must be getting close to some fresh rubber... :P
« Reply #14 on: November 06, 2013, 02:27:26 PM »
I still have some N50 15s Formula 1 Super Stock
any one remember those? :)  on some 12 in wide slotmags
the widest tire you could buy in Sweden in the 70s ;D ;D
maby some longer shackles and air shocks and i can fit
them on my 64 Galaxie
