Author Topic: Torque converter  (Read 839 times)
Torque converter
« on: November 06, 2026, 12:19:55 AM »
So as some know when I had my motor redone with bigger cam while I was waiting for motor I had a tranny shop just check tranny. Go through it and just check stuff. Tranny worked fine just a checkout. When I got it back he said are you sure this tranny worked good I said yes of course even showed him some videos were you can hear tranny shifting good. He said it’s gonna be even better. So I got motor back and used the same 3000 stall TCI torque converter went to the track and had terrible 60ft times sometimes as bad as 1.69. Talked to my tranny guy and he couldn’t remember what he played around with so he said take it out he will check it. He found nothing and said maybe I need a valve body. Now I had planned on getting another converter but after motor build didn’t have extra money so while it was out I got a 4200 stall from ATI. Tried to put it all together and motor would barely bolt to tranny and no play for converter. Called ATI and after them telling me my measurements are wrong and I don’t know how to put a converter in they said if I want to send it back I can but there not going to pay for shipping if converter is fine. So already bad taste in my mouth. A few days later I call them and they said they are fixing it they made me a converter for a C4. So I finally get it all back together and have the same 60ft times. So now in my mind I went back to what my tranny guy said about needing a valve body and take tranny out and I’m gonna send it to Broader to get done and have piece of mind that it’s done right. Now during this time I’m going through a prostate cancer problem and got a surgery date and didn’t have time to ship it and a buddy of mine told me about a tranny place in Delaware and I called them told them the story and they said they would meet me half way so I had a buddy of mine meet the tranny guy in Jersey to pickup tranny. Mean time I have surgery and am laid up. Tranny gets done they meet in Jersey they give me a good deal because everything in it was new they did a forward manual valve body also. They also couldn’t find what my tranny guy did. So I get it all together after I heal and go to the track and still 60 ft times are the same. Now I’m not sure if whatever my original tranny guy did something that nobody can find. So I just lived with it for a season and saved up and finally had Broader do my tranny and make no mistake tranny shifts better than ever but still have bad 60 ft times. So I I lived with it for the rest of the season and this year at the reunion I did a cellphone video of my tach and my 4200 stall converter  only has 3200 stall so of course it’s the same as my old converter. So after a lot of money in trannys I believe I need to have my converter checked. But before I take anything apart I want to temporarily hook up the trans brake and see what it will let me stall it to. So after this whole rant my question is if I do the transbrake thing will that for it to show me the stall speed. I was told it won’t go higher than whatever the stall is. If I’m wrong please say so. Now my other problem is because of my problems withATI I’m Leary to have them look at it again. Do I have to use someone else? A little guidance would be great. In my mind which is a dangerous place to be I was thinking of getting a converter through Broader but not sure what to do.
Re: Torque converter
« Reply #1 on: November 06, 2026, 08:19:04 AM »
why do you think internal transmission problems is why your 60ft is bad ? There is no difference between first gear manual VB and verses first gear automatic VB.  Unless two clutches are binding or wrong gear starts look else where. Is stall speed close to advertised stall ? My 5000 rpm converter will power brake 4800 rpm as an example.
475fetoploader
« Reply #2 on: November 06, 2026, 10:03:18 AM »
     A trans brake will find you the actual stall speed of the converter yes.  I don't know all of your combination, but am I understanding the slower 60 ft times started the same time a  larger camshaft was installed?
1967  519 c.i.  TKX 5 speed
mike7570
« Reply #3 on: November 06, 2026, 12:01:18 PM »
Joel, I can’t run a trans brake in the stocker because of the rules. I did have one in my super-gas Mustang with the tunnel port and the power glide. I did not have a 2step on the car so it was stage set the button and put it to the floor when both cars were staged. The trans brake will hold the car slightly below the converter flash point. My 8” 5000 stall converter actually stalled to about 4800-4900 sitting on the brake. You could test it without a 2step to see what the stall is.
On your 60’ times, are you still running 3.70 gears? What size tire and where is your timing set?
I assume you have full advance in by about 2500 rpm, and if you only at 33-34 degrees you may be too low for the cam and combination. Iron heads usually want more timing than aluminum but you really want to read your plugs and make some passes bumping it up until it slows down.
For reference my car at 3,280lb leaves about 1.36-1.39 60’ and I feel I’m a little slow and I’m trying to pick it up to low 1.30’s
Combination - 428 .060 over, stock Edlebrock heads, Shelby intake, 850 vacuum secondary carb, stock compression and cam lift. C-4 8” ATI converter, 4.86 gear 29.5 tall tires, Cal Tracs set in the middle no preload. Timing currently around 37 degrees, still experimenting.
« Reply #4 on: November 06, 2026, 09:44:12 PM »
So e philpott I originally thought I had an Internal problem because my first tranny guy told me he did something and when I asked him what he did he said he couldn’t remember. And I just didn’t think converter would be a or the problem.
475 Fe toploader yes that was my question so it will give me my stall good. And yes my other camshaft a 3000 stall was perfect with my solid flat tapped 245/254 @50 on a 112 .
Now I’m at 258/265 on a 112 solid roller. Max torque at like 4750.
Mike I’m on a 26 inch tire due to having to big of a brake in back that I bought so many years ago so I have to use a 16 inch rim to clear. And yes have a 3.70 gear. I am at 33/34 but have aluminum heads. I just put split monos on there and boy did they make a difference. I remember you saying one time about the separation my car has and now there’s hardly and. Had a great outing this past weekend after I put them in see drag section. I had a 149 60 ft this weekend but with the right converter I think I’m gonna be better. Now I can’t wait to check it gonna get there this weekend.
« Last Edit: November 06, 2026, 09:47:15 PM by Stangman »
mike7570
« Reply #5 on: November 07, 2026, 12:06:32 AM »
I see, the 16” rims with 26” tires and 18 or 19 pounds of air are going to be stiffer than the typical 30” slicks you see on almost all the cars in the stock and super stock pits. That’s probably why you had some tire spin, and they may even spin a little sometimes that you don’t notice giving you the 1.60’s 60 foot.
A lot of guys run the timing on their aluminum heads around the 33-34, Blair advised me to run more advance with my combo. Do you run pump gas or race fuel? Racing fuel requires a little more timing than pump gas because it burns a little slower
You could send the converter back to ATI and ask them to increase the stall some.
I think your car would benefit a lot with more stall and timing. Next would be to try a taller tire and gearing. Did you keep the 4.11’s ?
« Last Edit: November 07, 2026, 12:08:41 AM by mike7570 »
gregaba
« Reply #6 on: November 07, 2026, 01:01:35 PM »
If you do decide on a new converter then you might consider Circle D converter's.
I have used 4 of them in the past and could not be more satisfied.
Made from solid billet and work great.
Greg
« Reply #7 on: November 07, 2026, 01:47:05 PM »
I thought I went on their website once and didn’t see anything for a c6.
« Reply #8 on: November 08, 2026, 07:36:47 PM »
Mike the cheapest way to fix converter would be to send it back to ATI but have had 2 bad experiences so I don’t trust them. But I’m gonna talk to Blair and see if he can make a call to Charlie if he even works there anymore. I do run a lot of initial timing around 26 and only have 8 in dizzy which if you read my post a month or so back for some reason I only have 4 in dizzy so I bumped it to 30. Not ideal but I will be addressing that over the winter too. I did get a 1.495 60 ft time last weekend so I think the split monos are working.
« Reply #9 on: November 09, 2026, 07:33:01 PM »
Joe, about 25 years ago, I ran a C6 in my Fairmont, with the 428. I had a 8" TCS convertor, and originally was foot braking, with a reverse pattern manual valve body from TCI. The most that I could ever get was 4500 stall , at WOT with the foot brake, but later on, I switched to  a Ford Motorsport/Art Carr transbrake valve body. Like Mike, I did not have a 2 step, so I was launching the car at WOT on the transbrake, and at WOT on the transbrake, I could get 5200 RPM from the same convertor. By the way, my 60 foot times dropped almost a full tenth, leaving at WOT, from mid 1.40s, to mid 1.30s, but of course, that can only happen if the car hooks up well on the transbrake. My understanding is that drag radials don`t like hard hit shock loads, which is why you very rarely see a stick car run radial slicks, or drag radials. But if you leave on the transbrake at a lower RPM with a 2 step, you may be just fine. Personally, I like to gear a car to be at redline at the 1/4 mile mark, but I understand that you do more street driving than drag racing.
« Reply #10 on: November 10, 2026, 12:00:50 AM »
Thanks Rory. I do have a set of Hoosier slicks I got like 8 months ago just need rims. I will be using them when I use the brake. Maybe with the converter I have I can get 4500 which would be fine my max torque is at 4750.
« Reply #11 on: November 13, 2026, 07:17:24 PM »
So got over to the car today and let it warm up and put it in third gear and gave it a quick full throttle blip. Now the car is still tied down from the track in the trailer so I was a little hesitant but got about 4400 out off it. Not sure what this means but I would assume with a trans brake I will get the same. I just don’t like that if I footbrake the car it seems I’m only getting 3200 or so.
