Author Topic: Guess the horsepower  (Read 1616 times)
fastback 427
« on: August 22, 2026, 07:53:15 AM »
Finally finished the 427 for my mustang. It was an older build, high compression 427, 428 crank, Dove top end. I was tired of the race gas pain so wanted pump gas. The stroker kit was from Blair, Scat forged 4.25, molnar rods, diamond pistons. R and R in Minnesota did the machine work. I had picked a cam from Bullet, solid flat tappet, for my Dove heads. In the time after, the trick flows came out, so I ordered a set from Brent, he had them ported a bit, and set them up for my cam. I will say we were nervous about breaking it in, due too the big lift, so he used beehive springs, titanium everything else, and a light spring pressure. The intake is a Dove single plane with a dominator top welded on.
So basically it is a 488 cube, 11 to 1, pump gas, not ideal cam, 1050 carb. I will post numbers after some guesses.
Jaime
top end toploader
67 mustang coupe project
74 f100 xlt 390 c6 factory ac
Re: Guess the horsepower
« Reply #1 on: August 22, 2026, 11:37:32 AM »
It would be helpful to have the cam details.
fastback 427
« Reply #2 on: August 22, 2026, 11:53:10 AM »
.693 int. 688 ex. 263/ 270 at 50 108 lobe.
Jaime
top end toploader
« Reply #3 on: August 22, 2026, 01:53:32 PM »
I'll play
605 hp
chilly460
« Reply #4 on: August 22, 2026, 02:19:53 PM »
675
« Reply #5 on: August 22, 2026, 02:26:01 PM »
685
fastback 427
« Reply #6 on: August 22, 2026, 02:58:15 PM »
She might be a bit of an over achiever..  723.1 HP, 638 tq
Jaime
top end toploader
Dumpling
« Reply #7 on: August 22, 2026, 05:42:31 PM »
505 HP
Stangman1
« Reply #8 on: August 22, 2026, 06:56:02 PM »
Wow nice setup. Love a solid flat tapper. Nothing sounds better.
« Reply #9 on: August 23, 2026, 12:23:42 AM »
Almost, 1.5 hp per CI, I'll say! Wow, was I way off. I should have allowed more for the heads and lift....alot more.
« Reply #10 on: August 23, 2026, 07:12:04 AM »
Nice work!
fastback 427
« Reply #11 on: August 23, 2026, 12:40:24 PM »
Thanks for the comments guys, very happy with how this turned out, should motivate my mustang pretty damn good.
Jaime
top end toploader
1967 XR7 GT
« Reply #12 on: August 26, 2026, 07:49:12 AM »
After the results of 723.1 HP, 638 tq and state a bit of an over achiever., why would you then say "not ideal cam" ?
I see a combination that worked and made really good numbers. What were the heads flow numbers ?
Richard
fastback 427
« Reply #13 on: August 26, 2026, 07:29:39 PM »
1967 XR7 GT, That cam was picked for my set of dove medium riser heads, definitely different flow, runner size and chamber. Not sure how much that affects it but I was told a different cam would help. For what it's worth, I am extremely happy with the results, hopefully the track times back it up.
Jaime
top end toploader
