Author Topic: High Riser intake manifold question  (Read 3354 times)
0 Members and 3 Guests are viewing this topic.
338Raptor
« on: June 14, 2026, 01:33:17 AM »
Can someone educate me about the differences between the different OE High Riser intakes Ford made in the 60’s?
I listed the ones I know of but I’m sure I’ve missed a few.
C4AE-9425-E   1x4
C4AE-9425-G  1x4
C4AE-9425-D   2x4 dual plane
C4AE-9425-F   2x4 dual plane
Was there a 2x4 tunnel wedge version?
pbf777
Re: High Riser intake manifold question
« Reply #1 on: June 14, 2026, 01:31:58 PM »
     Of O.E.M. Ford, I also have examples of the 1x4 without casting/engineering numbers (looks a lot like the "E") and Weber intakes.
     Apparently DOVE made a few H.R. "Tunnel-Wedge style" intakes.    :)
     Scott.
« Last Edit: June 14, 2026, 01:33:50 PM by pbf777 »
pumpbldr
« Reply #2 on: June 15, 2026, 06:35:53 PM »
The main difference between the E & F 2x4 intakes is the carb mounting surface. One is flat, the other is at an angle. Might be some more to it than that.
Doug aka pumpbldr
Precision Oil Pumps
pbf777
« Reply #3 on: June 15, 2026, 07:47:12 PM »
    I'm thinking you meant "D" & "F", if you were speaking of the 2 x 4 intakes.   :-\
    And if so, there's definitely more to it than that!  Find a picture of each and compare the runner execution.   ;)
    Scott.
« Last Edit: June 15, 2026, 07:54:22 PM by pbf777 »
338Raptor
« Reply #4 on: June 15, 2026, 10:00:12 PM »
I looked at a D today. I was told it has sufficient spacing to use carbs with metering blocks and it had an angled mount.
428kidd
« Reply #5 on: June 16, 2026, 07:39:05 AM »
There is a XE 2x4 also. The D is sort of angled in the center like an X so is the XE. The High riser has its own carb spacing on the 2x4 stuff because the carbs from the factory used metering blocks front and back. Ive always heard the F intake is a good 25 plus HP over the D . Dove made the tunnel wedge for the high riser but it is usually only for the raised port heads.
« Reply #6 on: June 16, 2026, 10:22:24 AM »
There was an early style 4V HR intake without a part number that I have worked on.  It had terrible flow distribution between the runners. It is rare.  Here is a picture of it compared with the -E.  Joe-JDC
pbf777
« Reply #7 on: June 16, 2026, 12:19:13 PM »
     Yes, the "E" 'was' better, but then the "G" example is better again and is definitely the one you want!   :)
     Scott.
338Raptor
« Reply #8 on: June 17, 2026, 12:42:52 AM »
428KIDD: Is the XE better than the F?  Have you heard?
428kidd
« Reply #9 on: June 17, 2026, 07:34:13 AM »
F is better than the XE or the D as far as performance goes. Robert Pond is making new F intakes and F heads and can be purchased through Chris Whitney.
John67427
« Reply #10 on: June 17, 2026, 08:27:07 AM »
I have the one of the Dove Hi Rise tunnel wedge intakes. Not sure how many Jim Dove sold
338Raptor
« Reply #11 on: June 17, 2026, 11:31:28 AM »
John67427: does it fit the stock C4AE-6090-F high riser port locations?  If so, are you interested is selling your Dove Tunnel Wedge?
John67427
« Reply #12 on: June 17, 2026, 07:37:40 PM »
At the present time it’s not for sale. It does have the the standard Hi Rise ports configuration, not the Paquet port. I tried to post photos but this site doesn’t like I phone photos.
338Raptor
« Reply #13 on: June 17, 2026, 09:58:00 PM »
If you change your mind I’m interested.
428kidd
« Reply #14 on: June 18, 2026, 07:33:06 AM »
They made standard high riser port location and raised port location in them.
