Author Topic: Hydraulic Roller Lifter Adjustment  (Read 779 times)
petew
« on: June 10, 2026, 08:28:03 PM »
A hydraulic roller cam with Harland and Sharp roller rockers set the preload at 1/4 or 1/2 turn past zero ?
Re: Hydraulic Roller Lifter Adjustment
« Reply #1 on: June 11, 2026, 03:53:11 AM »
Standard travel lifters?  One full turn.
petew
« Reply #2 on: June 11, 2026, 05:50:39 AM »
Will do , thanks
« Reply #3 on: June 11, 2026, 09:07:48 AM »
FYI on an FE, 7/16-20 adjuster and adjustment directly at the pushrod
- 20 threads (turns) per inch on the adjuster
- 1 inch divided by 20 to solve for 1 turn = .050 which turns into your preload amount after zero
Rocker pivot style like a small block won't work the same, but easy breezy on an FE
