Author Topic: Electric water pump  (Read 855 times)
69ramair
Electric water pump
« on: May 18, 2026, 01:51:55 AM »
Hello I am looking for some suggestions on how to wire in an electric water pump. Is there some way to hook it up so you would know that the pump is working if the engine is running? Could you use the the power wire to the coil to turn on a relay for the pump or could this interfere with power output to the coil?  Electrical is not a strong point for me so any suggestions would be appreciated
GerryP
Re: Electric water pump
« Reply #1 on: May 18, 2026, 06:03:30 AM »
You can't run anything from the coil + other than the coil.  If you want to have the pump turn on only when the engine is running, use a relay with the trigger coming from the alternator stator terminal.
66FAIRLANE
  • Andy
« Reply #2 on: May 19, 2026, 05:54:41 PM »
If you have an electric fuel pump you could use the same method you use for that.
69ramair
« Reply #3 on: May 20, 2026, 11:40:41 PM »
Thanks for the suggestions I ordered a wiring kit and I will trigger the relay off or the alternator
