Author Topic: Coolant  (Read 1107 times)
475fetoploader
Coolant
« on: May 08, 2026, 03:03:44 PM »
Has anyone ran the Evans high performance, or classic car Waterless engine coolant? If so was it a good experience, something you recommend?
1967  519 c.i.  TKX 5 speed
Re: Coolant
« Reply #1 on: May 08, 2026, 10:28:38 PM »
My dad uses it. I run 1 gallon of it and the rest water. It’s like 52 dollars a gallon so we drain it carefully it’s like gold. Not exactly sure if it runs any cooler but supposedly it’s NHRA legal. Normally I drain my coolant before I go to the track and run like a water wetter but I think your allowed to run this stuff at the track. If anyone knows for sure let me know
Re: Coolant
« Reply #2 on: May 09, 2026, 10:57:58 AM »
There is no NHRA rule that prohibits running any kind of antifreeze at the track. Conversely, there is no NHRA rule requiring any particular kind, or brand, of antifreeze either. An individual track may make their own rule prohibiting antifreeze, or requiring water only, and some might, but it’s not an NHRA rule.
Mind you, I’m not suggesting it’s a good idea, or recommending it, but it’s not something most tracks even ask or check for in tech inspection. This question comes up all the time on various “Drag & Drive” forums, especially those for events run when the weather turns cold.
The NHRA rule book is available online now days for anyone that wants to check.
Re: Coolant
« Reply #3 on: May 09, 2026, 01:23:08 PM »
Thanks Kevin. I like to get a little in there for the water pump and corrosion.
mygasser
Re: Coolant
« Reply #4 on: May 09, 2026, 05:10:58 PM »
you're not supposed to mix it with water. you're supposed to flush the system with their coolant flush https://www.ebay.co.uk/itm/313289717693?chn=ps&_ul=GB&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&mkscid=101&itemid=313289717693&targetid=2446591572460&device=c&mktype=pla&googleloc=9195269&poi=&campaignid=23488091938&mkgroupid=190697591446&rlsatarget=pla-2446591572460&abcId=10587450&merchantid=7422994&gad_source=1&gad_campaignid=23488091938&gbraid=0AAAAAD_Lr1cXOYpUN2QSrmHhwRnTT_FA2&gclid=CjwKCAjwtvvPBhBuEiwAPMijr2dd3F0q-97YKgNVJ-pcpUziZSpSM7aIwcNEyA-DR2QKYe1UUsdrThoCPygQAvD_BwE to draw any remaining moisture (water) from it. then ad the waterless coolant neat. the giveaway is the name.... water'less'. it supposedly doesn't do it's job if there's any water present.
neil.
Re: Coolant
« Reply #5 on: May 10, 2026, 09:16:42 PM »
Hmm didn’t think about that my dad runs it by itself. I was really using it for the lubrication. Ok I better do better research thanks
