Author Topic: Lykins Motorsports 367ci Ford SBF Tunnel Port  (Read 1394 times)
« on: April 23, 2026, 07:51:11 AM »
Performance Summary:
      Cubic Inches:  367             Dyno brand:  Stuska
      Power Adder:                Where dynoed:  Dale Meers Racing Engines
      Peak Horsepower:  516
      Peak Torque:  466
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  World Products cast iron, 4.155"
   Crankshaft brand, cast or forged, stroke, journal size:  Bryant, 3.385" stroke, Honda rod journal
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Dyers
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Custom Racetec, 11.5:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Calico coated Clevite main/rods, Durabond cam
   Piston rings brand, size, other notes:  Mahle
   Oil Pump, pickup, and drive:  Peterson Fluid Systems dry sump
   Oil pan, windage tray, oil filter adapter:  Custom Kevko dry sump
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Lykins Motorsports billet core solid flat tappet
   Lifters brand, type:  PPP, DLC coated tool steel
   Timing chain and timing cover:  Cloyes billet
   Cylinder heads brand, material, port and chamber information:  Factory Ford Tunnel Port "race" heads
   Intake valve brand, head size, stem size:  Custom Ferrea titanium, 7mm
   Exhaust valve brand, head size, stem size:  Custom Ferrea titanium, 7mm
   Valve springs brand, part number, specs:  PAC dual spring
   Retainers and locks brand, part number, specs: PAC titanium
   Rocker arm brand, type (adjustable or non-adj), material, ratio: T&D race
   Rocker shafts and stands, brand, material:
   Pushrods brand, type, length:  Custom Smith Brothers, 3/8" diameter intake, 5/16" diameter exhaust
   Valve covers, brand, type:  Cast aluminum
   Distributor brand, advance curve information:  MSD Billet
   Harmonic balancer brand:  ATI
   Water pump brand, type (mechanical or electric):  Milodon cast iron
   Intake manifold brand, material, porting information:  Factory Ford Tunnel Port
   Carburetor(s) brand, type:  Dual Holley ~715cfm, per Drew Pojedinec
   Exhaust manifolds or headers brand, type:  Dyno headers
Re: Lykins Motorsports 367ci Ford SBF Tunnel Port
« Reply #1 on: April 23, 2026, 07:52:00 AM »
Pretty rare engine!
Bullet proof bottom end per customer, for road race application.  He wanted to see what the factory Tunnel Port race heads and intake would do out of the box.  Nothing like a modern cylinder head, but not too shabby either.
« Reply #2 on: April 23, 2026, 07:56:28 AM »
« Reply #3 on: April 23, 2026, 09:18:25 AM »
Very cool build, modern power with rare old parts. Nice work!
« Reply #4 on: April 24, 2026, 08:19:00 AM »
Sweet engine , that's a lot better HP numbers than the other TP SBF you did
