Author Topic: Lykins Motorsports 408 Cleveland, 9.6:1 Street Engine, 545hp  (Read 1247 times)
« on: April 23, 2026, 07:45:34 AM »
Performance Summary:
      Cubic Inches:  408             Dyno brand: Stuska
      Power Adder:  Nope        Where dynoed: Dale Meers Racing Engines
      Peak Horsepower:  545
      Peak Torque:  545
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes:  Factory 351C 2-bolt main
   Crankshaft brand, cast or forged, stroke, journal size:  Scat 9000 series, 4"
   Connecting Rods brand, material, center to center distance, end sizes, bolts:  Scat I-beam
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR:  Mahle dish, 9.6:1
   Main Bearings, Rod Bearings, Cam Bearings brand and size:  Calico coated Clevite main/rods, Durabond cam
   Piston rings brand, size, other notes:  Mahle
   Oil Pump, pickup, and drive:  Melling M84AHV, Milodon pickup, ARP shaft
   Oil pan, windage tray, oil filter adapter:  Milodon front sump, 9 quart
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050"):  Custom Lykins Motorsports hydraulic roller
   Lifters brand, type:  Morel
   Timing chain and timing cover:  Cloyes billet timing set
   Cylinder heads brand, material, port and chamber information:  Factory 4V quench heads
   Intake valve brand, head size, stem size:  2.190", 11/32", SI stainless
   Exhaust valve brand, head size, stem size:  1.710", 11/32", SI stainless
   Valve springs brand, part number, specs:  PAC dual spring
   Retainers and locks brand, part number, specs:  PAC steel retainer
   Rocker arm brand, type (adjustable or non-adj), material, ratio:  Scorpion 1.73:1
   Pushrods brand, type, length:  Trend 5/16", .080" wall
   Valve covers, brand, type:  Temporary chrome, stamped steel, factory style
   Distributor brand, advance curve information:  Factory reproduction, Pertronix conversion
   Harmonic balancer brand:  Powerbond
   Water pump brand, type (mechanical or electric):  Electric water pump on dyno
   Intake manifold brand, material, porting information:  Joe Craine ported Edelbrock Performer RPM Air Gap
   Carburetor(s) brand, type: Holley 750 DP
   Exhaust manifolds or headers brand, type:  Dyno headers
« Last Edit: April 23, 2026, 08:03:29 AM by blykins »
Re: Lykins Motorsports 408 Cleveland, 9.6:1 Street Engine...
« Reply #1 on: April 23, 2026, 07:46:49 AM »
Just gotta say, factory 4V Cleveland heads are some bad chicks.
9.6:1, no port work, dual plane intake, lots of horsepower and lots of torque.
Peak hp rpm was at 6000 rpm.
« Reply #2 on: April 23, 2026, 07:58:26 AM »
preaction
Re: Lykins Motorsports 408 Cleveland, 9.6:1 Street Engine, 545hp
« Reply #3 on: April 23, 2026, 08:41:57 AM »
Did you use an oil slinger on this build ?
« Reply #4 on: April 23, 2026, 08:54:30 AM »
I don't use oil slingers on any builds.  No factory tins in any of my engines.
