Author Topic: All aluminum Dove flat tappet build (formerly who knows their SK)  (Read 1852 times)
Just an update, absolutely a Dove, a nice one, but a Dove
https://www.fordfe.com/viewtopic.php?f=74182&t=170820&from_new_topic=1
« Last Edit: May 04, 2026, 12:38:52 PM by My427stang »
Re: Who knows their SK castings?
« Reply #1 on: April 22, 2026, 05:19:37 PM »
FWIW - I did an AI comparison of all the pictures and it came up 100% certain it was Dove :) and all the reasons it told me so.  It even sent me for more pictures to prove it.
Re: All aluminum Dove flat tappet build (formerly who knows their SK)
« Reply #2 on: May 04, 2026, 12:52:00 PM »
So the game plan is this.  Many of the parts are in the recently built engine, so you'll see some odd choices compared to most of my builds.
Dove aluminum block - I just pressure tested, all good and was running and likely doing well as drained oil and indications of a good burn pattern across all 8.  Going to tighten up the main registers a little, align hone due to crooked mains and full CnC prep.
Ford 3.98 crank - already internally balanced, will mag, verify balance and run with a polish if all good.
Eagle 6.49 H-beams - found two caps swapped by prior builder, game plan is to check bore sizes and swap caps back, resize as needed.
Ross flat tops - 2618 pistons with 1/16, 3/16 rings.  This one may not stick, need to see piston to wall clearance, if we can get there with a torque plate, we will reuse with a set of Mahle rings, if clearance is excessive will go Racetec with 1mm/2mm pack.  Currently flat top.  Will be shooting for around 10.5:1 compression max, if specs good will have to CnC a little repeatable dish, but we'll see after I pour the heads
Custom flat tappet and tool steel lifters - No oil to lifters, so going a little conservative with a Nitrided iron core and tool steel lifters, probably going to end up with a 6000 RPM peak for a street car with a snotty LSA, more to do before I can pick a design
Dove SK heads - will put on the flow bench this weekend. They look hefty on the intake side, not too sexy on the exhaust.  Once I get numbers we'll see if they need rubbing or just a modern valve job and good seals.  I expect these to be pretty stout
Intake - Customer initially wanted a TW and dual look-a-like carbs, watching budget a bit, but will pin down before cam choice.
Should be a snarly 452-ish inch all aluminum Dove based engine in a TKX/4.11 T-bolt tribute
428kidd
« Reply #3 on: May 05, 2026, 06:59:43 AM »
Be a very cool build! Go TW!
« Reply #4 on: May 05, 2026, 01:02:04 PM »
Likely TFS TW and a pair of Drew's carbs
428kidd
« Reply #5 on: May 06, 2026, 07:11:06 AM »
I like it , or find an old Dove TW and do a all Dove build! But for the money the TF is was above average.
MeanGene
« Reply #6 on: May 06, 2026, 09:21:59 AM »
Gee, look what I have! Kinda like to keep the 660's but not married to them
« Reply #7 on: May 06, 2026, 02:59:44 PM »
Dual 600s from Drew planned for this one, all for a matching Dove but not sure it'd touch what I can get TFS for.
Shoot me a PM if interested in selling it bare, I'll talk it over with the customer.  Thanks!
