Author Topic: Still improving a little at a time  (Read 20871 times)
Faron
« on: October 02, 2025, 10:52:23 AM »
My 68 ran a best of 10.63 @ 126.95 this year with a best 60ft of a 1.46 C-6  with low gear set and 3.66 Rear Gears Tight 10 inch street Converter leaving at 2300 Car weighs 3450 , presently
Re: Still improving a little at a time
« Reply #1 on: October 02, 2025, 10:21:01 PM »
Nice work.
Faron
« Reply #2 on: October 03, 2025, 03:32:35 AM »
Since it just became available lately, I think I'm going to give E85 a shot
« Reply #3 on: October 03, 2025, 10:08:16 PM »
If the fuel systems up to it I believe you just have to fatten up the jets
hbstang
« Reply #4 on: October 09, 2025, 04:16:28 PM »
just remember,it takes a full 1/3 more fuel flow with e85 over gas.make sure your pump is rated for e85,and carbs or injectors have enough flow.especially with a blown engine .
6667fan
  • Every Second Counts
« Reply #5 on: October 11, 2025, 02:23:48 PM »
Awesome!
Have you tried different final gear ratios? Seems tall but obviously you are getting it to work. How low is that first gear? What are trap rpms?
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
Faron
« Reply #6 on: October 19, 2025, 09:57:47 AM »
I tried 4.11 it went slower!!  It wasn't spinning, I believe it has to do with the converter being so tight, the higher ratio gears Load the converter ( on the converter ) Sadly I cant give you trap rpm because like most tracks its mostly 1/8 mile racing now ( I hate 1/8 Mile ) First
 gear is 2.72
