Author Topic: ------------  (Read 4066 times)
fairlaniac
« on: September 13, 2025, 07:05:42 AM »
Looking for a set of 8 rocker stands. Used is fine. I don't need fancy aftermarket unless they are cheap :-)
I picked up a set of OEM stands at a swap meet a few years ago and thought I'd use them on this stock 390 I'm putting together with parts I have lying around. I discovered that the bore is oval. .836 up and down and .845 across. I assume someone torqed them like lug nuts? So before you offer any, could you check the bore for roundness. If it helps, I have two NOS stands so if you have a broken set of 6 or 7, that will work too.
Thanks,
fairlaniac@fairlanet.com
« Last Edit: November 14, 2025, 12:57:28 PM by fairlaniac »
Doug Bender
1966 Fairlane 427+/5 Spd TKX
1978 F150 2WD 390
JamesonRacing
Re: Wanted: Plain Jane rocker stands
« Reply #1 on: September 13, 2025, 08:18:58 AM »
Hi Doug.  I think the OEM stands are always deformed after installation, as they clamp the shaft.  Look at the OEM 427 stands, that were beefier, but had a bend cut on one side to allow bending.  I think you'll be fine with the ones you have, though you might have to use a soft mallet to install them.
fairlaniac
« Reply #2 on: September 13, 2025, 12:56:47 PM »
I would use them except the shaft will not go through. I tapped one on and it was way too tight.
Doug Bender
1978 F150 2WD 390
FERoadster
« Reply #3 on: September 13, 2025, 05:22:52 PM »
I've got at least 6 extra rocker assemblies. I'll take a couple apart and check for roundness.
It will be a day or two. I think they would fit into a small flatrate box.
Richard
rockhouse66
« Reply #4 on: September 14, 2025, 07:00:59 AM »
You could buy my complete setup with end stands as an option.
https://fepower.net/simplemachinesforum/index.php?topic=12864.0
Jim
fairlaniac
« Reply #5 on: September 14, 2025, 10:33:29 AM »
Thank you all for your responses. I purchased a new set just to be safe.
Thanks again!
Doug Bender
1978 F150 2WD 390
