Author Topic: Mallory distributor gear  (Read 7326 times)
Royce
« on: May 24, 2025, 07:45:39 AM »
I am putting an FE into an RCR GT40. It's a tight squeeze. No room for water pump and the MSD or even stock Ford distributor will not work  My only option seems to be an older Mallory with a marine crab cap.. The FE has a roller cam. What  gear would I use . It's a YL/25 Mallory distributor..
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
Re: Mallory distributor gear
« Reply #1 on: May 24, 2025, 07:50:44 AM »
What's the shaft diameter, Royce?  You need a steel gear.  They're available in .467" and .531".
pbf777
« Reply #2 on: May 24, 2025, 03:20:07 PM »
   Maybe even .500"?   :-\
   Scott.
philminotti
« Reply #3 on: May 25, 2025, 03:32:37 PM »
Hi Royce
Not to change the topic, but what transaxle are you gonna use?
Phil
Dumpling
« Reply #4 on: May 27, 2025, 11:14:42 PM »
Coil packs?
« Reply #5 on: May 28, 2025, 09:26:01 PM »
Mallory is/was .500
Ford428CJ
  • FE FREAK!
    • Hillside Auto
« Reply #6 on: June 07, 2025, 09:22:34 AM »
I have a couple YL Laying around my shop and I’ll go measure the shaft….
Wes Adams FORD428CJ
64 Falcon 428FE
JumpinJim
« Reply #7 on: June 07, 2025, 10:24:38 AM »
My old YL is a 37 series #3755301 and the shaft diameter is .467
I used Crane steel gear #34970-1 (Not available any longer?)
