Author Topic: Cam shaft spec review  (Read 4984 times)
justintyme73
« on: May 02, 2025, 09:32:29 AM »
I am still waiting on my block back from the machine shop so thought I would have all the Fe gurus here review my cam specs. I Ordered a custom hyd roller from cam research since the are local to me and I like to keep local guys in business too...going in a 428 .040 over with a stroker kit from Brent lykins, trick flow heads, rpm manifold, hooker headers
Going to be driving a 67 Galaxie 3.89 rear, street cat, power brakes, converting it to a 5 speed tkx
« Last Edit: May 02, 2025, 09:38:32 AM by justintyme73 »
Re: Cam shaft spec review
« Reply #1 on: May 02, 2025, 10:42:44 AM »
pretty mild cam for those cubic inches , I would probably want more cam myself
justintyme73
« Reply #2 on: May 02, 2025, 11:16:24 AM »
is it hard for everyone to see that attachment, looks weird when I try to view it. I was kind of thinking it might be on the small sid
Specs,
gross lift .545/.545
adv duration In 272 ex 276
@ .050  218/222
.050 valve timing @ 106 icl
intake BTDC 3, Abdc 35
ex   bbdc 45  atdc -3
lobe lift .315
lobe separation 110
« Reply #3 on: May 02, 2025, 11:35:54 AM »
Lots to unpack, but bottom line, it's not right.
- Depends on static compression but too small advertised, intake side likely 20 degrees short for a 10:1 motor
- Not enough .050, also 15-18 degrees short
- Giving up lift for no reason with good heads
- Not enough split, needs more exhaust lobe proportionally, 10+ more exhaust than intake.
- LSA would need to change with lobe change to keep idle vacuum
I'd be something like 290-ish/235-237-ish, intake, 300 ish exhaust, 246-248 exhaust, over .600 lift, and LSA to keep vacuum where you want it.
Brent can get you there, or I can if he is busy, or if you want to buy from Cam Research, it needs to meet something closer to 290/235 298/245 114 LSA, .600+ lift, degree to match your static.  I do not have their lobe chices to dig deeper.  I use Comp, Bullet, and in very rare cases Oregon and choose the lobes I want
MeanGene
« Reply #4 on: May 02, 2025, 12:32:10 PM »
JMHO, but you have some fairly expensive go-fast parts  that would be wasted by a cam that would be nice for a street 390
justintyme73
« Reply #5 on: May 02, 2025, 01:22:12 PM »
Yea honestly I talked to him twice on the phone, about a couple different combos, but when I ordered thought I was clear about what I had, and unfortunately did not write down the specs he said at the time but I feel like he possibly ground me the smaller cam we talked about.....I will probably sell it and get another.
« Reply #6 on: May 02, 2025, 04:27:03 PM »
That cam will sound like a "stock engine" with 462+ cubes, and even with a good combustion chamber it might be fuel sensitive considering the low RPM torque peak (cylinder pressure) and the weight of the vehicle.
« Reply #7 on: May 02, 2025, 04:45:43 PM »
They done messed up.
justintyme73
« Reply #8 on: May 02, 2025, 07:49:53 PM »
Thanks all, much appreciated! You all confirmed what I was afraid of once I opened it...
