Author Topic: Gathering parts for a build  (Read 4854 times)
c9zx
« on: March 19, 2025, 05:08:08 PM »
I'm looking for a source for the "good" OEM style oil filter adaptor. Also, suggestions for a high flow mechanical fuel pump and aluminum mechanical water pump (not Edelbrock on principle alone). Thanks, Chuck
1969 Eliminator G code
CSX-7031 FIA Cobra
2007 Mustang GT, Whipple
1966 Cyclone GT
Urgefor
Re: Gathering parts for a build
« Reply #1 on: March 19, 2025, 07:20:16 PM »
A couple options for oil filter adapters
can be found here.
« Last Edit: March 19, 2025, 08:52:18 PM by Urgefor »
475fetoploader
« Reply #2 on: March 19, 2025, 08:20:21 PM »
Holley 12-390-11.  110 gph 3/8 pipe threads
Edit:  Holley website says 1/4 pipe threads.
« Last Edit: March 19, 2025, 08:25:04 PM by 475fetoploader »
1967  519 c.i.  TKX 5 speed
« Reply #3 on: March 20, 2025, 03:51:51 AM »
We all carry new OEM style oil filter adapters.
As for the fuel pump, the only two pumps I’d select for a 550 hp engine would be a Carter M6905 or an Edelbrock pump.
cleandan
« Reply #4 on: March 29, 2025, 10:29:41 PM »
Get a Carter M6905 fuel pump.
Take it apart and port/smooth out the internal flow passages as much as possible.
There are some tight, hard, corners in the casting.
Then get some brass fittings and port them too.
They do not need to be as thick walled as they are made.
This will result in a bit more flow from the pump and that should support your 550HP engine needs nicely.
MeanGene
« Reply #5 on: March 29, 2025, 10:56:49 PM »
I have a few clean OEM C8 big port adapters
c9zx
« Reply #6 on: March 30, 2025, 02:41:35 PM »
PM sent
CSX-7031 FIA Cobra
1966 Cyclone GT
