Author Topic: FE Intake Adapters  (Read 182420 times)
482supersnake
Re: FE Intake Adapters
« Reply #105 on: February 18, 2018, 09:16:28 PM »
No problem, I just glad you do what you do and hopefully it is worthwhile doing it.
hwoods
« Reply #106 on: February 19, 2018, 09:29:03 PM »
what is the part number of the 351C tunnel ram you have on the 13001 adaper?  Thanks
« Reply #107 on: February 19, 2018, 10:22:13 PM »
Weiand 1994
« Reply #108 on: February 20, 2018, 07:39:10 AM »
Jay, this project has taken on far more positive and intriguing dimensions that I ever thought it would....maybe you too!
Kudos on pursuing it to the the benefit of FE users!
« Reply #109 on: February 20, 2018, 09:49:29 AM »
Thanks Bob, the intake adapter has certainly made the FE engine more "modular", leading to more induction system varieties for medium risers, high risers, and tunnel ports.  I've mentioned this before, but when I did the high riser version of the adapter I made the casting even higher in the valve cover rail, to accomodate a port raised way up.  This makes my new head design possible, and will hopefully give a step function improvement in the horsepower potential of the engine.
« Reply #110 on: February 20, 2018, 12:42:13 PM »
Got a BBM block sitting and waiting ::)
