Author Topic: SFI Flexplate  (Read 10157 times)
mike7570
SFI Flexplate
« on: June 18, 2024, 04:24:12 PM »
Any good recommendations?  I have a neutral balance PA SFI flexplate but the date is expired.  I tried calling Performance Automatic but they are moving and won't be up and running until August. (Not sure they will re-certify) Summit sells PRW but I really don't want to use any of their products.
Thanks for any suggestions.
pbf777
Re: SFI Flexplate
« Reply #1 on: June 18, 2024, 06:59:15 PM »
       Who's climbing under the car, removing the inspection cover plate, looking for the decal and checking the date?   ::)
       Scott.
mike7570
Re: SFI Flexplate
« Reply #2 on: June 18, 2024, 10:12:36 PM »
       Scott.
No one yet but for a NHRA class car I would rather be legal. The rule was introduced to stock eliminator and there can be spot checks any time.
Kirk Morgan
Re: SFI Flexplate
« Reply #3 on: June 18, 2024, 10:29:10 PM »
They dont have to go under the car. They will ask you for the paper work for a recert or a new purchase. They checked Ray Paquet at Indy last year for his certs.
Re: SFI Flexplate
« Reply #4 on: June 19, 2024, 08:04:09 AM »
I just received an ATI flex plate for our race car. It's very lightweight. It came as a package with their torque converter.
mike7570
Re: SFI Flexplate
« Reply #5 on: June 19, 2024, 11:50:52 AM »
I saw that on their web site but it is listed for a C6 and E4OD doesn’t mention C4. Are the C6 and C4 torque converter bolts the same pattern?  (I haven’t really checked)
(Corrected)
« Last Edit: June 19, 2024, 01:36:18 PM by mike7570 »
pbf777
Re: SFI Flexplate
« Reply #6 on: June 19, 2024, 12:29:40 PM »
    There are two (common) O.E.M. bolt pattern diameters for C4. only one for the C6; but there are also converter mounting offset distances, which if I recall correctly the C6 only shares with the E4OD?   :-\
    Scott.
Sand hauler
Re: SFI Flexplate
« Reply #7 on: June 29, 2024, 11:07:24 PM »
I have a Hays SFI on mine.
Bobby-   Carlsbad, NM
JamesonRacing
Re: SFI Flexplate
« Reply #8 on: June 30, 2024, 07:29:57 AM »
I have a Reactor Products flexplate in my race car.  Billet aluminum.  Been trouble free.
Re: SFI Flexplate
« Reply #9 on: July 01, 2024, 10:33:51 PM »
If you get the ATI Flexplate make sure you get the spacer. I ordered a flexplate from Jegs and it didn’t come with spacer and starter was crashing into plate. Spent this weekend putting spacer in. Oh fun.
Jb427
Re: SFI Flexplate
« Reply #10 on: July 02, 2024, 06:01:11 AM »
I asked you Stangman if you got the spacer as it is required
If you buy an ati flexplate for an fe get the kit It comes with flexplate spacer and bolts too ATI Part #915722
Re: SFI Flexplate
« Reply #11 on: July 02, 2024, 10:31:14 PM »
My bad I don’t know if I missed your post or skimmed by it. Yes it would have been great advice. Next time I will pay better attention. One good thing is that it used much less spacers for converter clearance.
Jb427
Re: SFI Flexplate
« Reply #12 on: July 03, 2024, 02:42:50 AM »
Im glad you got it sorted  ;)
mike7570
Re: SFI Flexplate
« Reply #13 on: July 05, 2024, 11:02:22 PM »
I have the trans out and the ATI C4 converter has the 11 1/2” bolt pattern, so the ATI flexplate will work for my car as well. I’m going to see what the Reactor flexplate cost and how hard it is to get it recertified since they are not too far from me in SoCal.
« Last Edit: July 05, 2024, 11:03:53 PM by mike7570 »
69ramair
Re: SFI Flexplate
« Reply #14 on: July 06, 2024, 03:07:28 PM »
I ordered a PRW SFI flexplate before I heard about their quality issues and have it on my 464 589 hp engine and have not had any issues . I installed it with a power master starter and it works perfectly  . I have thrashed on it with drag radials and so far no issues
