Author Topic: FE/385 Dampeners  (Read 4859 times)
frnkeore
FE/385 Dampeners
« on: May 25, 2024, 04:29:10 PM »
Has anyone used a 385 dampener on a FE?
I'm considering doing this. I've never been into 460 so, I not familiar with the difference between the dampeners. It looks like it could be done though.
Frank
'60 Ford Starliner
'61 Fairlane 500
Re: FE/385 Dampeners
« Reply #1 on: May 25, 2024, 05:34:14 PM »
But why are they less expensive
frnkeore
« Reply #2 on: May 25, 2024, 07:11:46 PM »
yes,they are.
Frank
'60 Ford Starliner
'61 Fairlane 500
manofmerc
« Reply #3 on: May 31, 2024, 04:31:21 AM »
I believe I have a factory one I would send it to you for shipping .Those 460 dampers are much bigger in diameter than a FE version .If interested let me know I will check to see if I still have it.
Ghoughton
« Reply #4 on: May 31, 2024, 07:31:08 AM »
Yes you can. I’m currently using one. I’m using an aviad spacer with a dry sump drive, so I had to machine that to fit. It may work with a stock 385 spacer. And of course verify tdc and timing marks
frnkeore
« Reply #5 on: May 31, 2024, 11:04:57 AM »
Thank you, I have conformation on another forum that it will work, too.
Regarding spacers and pulley alignment, I make my own so, that isn't a issue.
Frank
'60 Ford Starliner
'61 Fairlane 500
BigBlueIron
« Reply #6 on: June 03, 2024, 09:34:18 AM »
Fluidamper uses the same balancer for FE and 385 series, it includes a spec for shortening the spacer.
