FE Technical Forum
FE/385 Dampeners
Topic: FE/385 Dampeners (Read 4864 times)
FE/385 Dampeners
May 25, 2024, 04:29:10 PM »
Has anyone used a 385 dampener on a FE?
I'm considering doing this. I've never been into 460 so, I not familiar with the difference between the dampeners. It looks like it could be done though.
Re: FE/385 Dampeners
Reply #1 on:
May 25, 2024, 05:34:14 PM »
But why are they less expensive
Reply #2 on:
May 25, 2024, 07:11:46 PM »
yes,they are.
manofmerc
Sr. Member
Reply #3 on:
May 31, 2024, 04:31:21 AM »
I believe I have a factory one I would send it to you for shipping .Those 460 dampers are much bigger in diameter than a FE version .If interested let me know I will check to see if I still have it.
Ghoughton
Jr. Member
Reply #4 on:
May 31, 2024, 07:31:08 AM »
Yes you can. I’m currently using one. I’m using an aviad spacer with a dry sump drive, so I had to machine that to fit. It may work with a stock 385 spacer. And of course verify tdc and timing marks
Reply #5 on:
May 31, 2024, 11:04:57 AM »
Thank you, I have conformation on another forum that it will work, too.
Regarding spacers and pulley alignment, I make my own so, that isn't a issue.
BigBlueIron
Sr. Member
Reply #6 on:
June 03, 2024, 09:34:18 AM »
Fluidamper uses the same balancer for FE and 385 series, it includes a spec for shortening the spacer.
FE Technical Forum
FE/385 Dampeners
