Author Topic: 464 fe  (Read 20612 times)
69ramair
464 fe
« on: May 23, 2024, 10:25:17 PM »
Performance Summary:
      Cubic Inches:   464            Dyno brand:SF 902 Pro
      Power Adder:   n/a            Where dynoed: Pro Street Dino plus
      Peak Horsepower:588.6 @ 5500
      Peak Torque: 605@ 4500
Horsepower and Torque Curves:
Engine Specifications:
   Block brand, material, finished bore size, other notes: C scratch
   Crankshaft brand, cast or forged, stroke, journal size: 4.25 scat
   Connecting Rods brand, material, center to center distance, end sizes, bolts: scat I beam
   Piston brand, material (caster, hypereutectic or forged), dish/dome volume, static CR: Mahle 20 cc dish. 10.3
   Main Bearings, Rod Bearings, Cam Bearings brand and size:
   Piston rings brand, size, other notes: Mahle 1mm 1mm 3mm
   Oil Pump, pickup, and drive:Melling HV
   Oil pan, windage tray, oil filter adapter: Canton 15-850
   Camshaft brand, type (hyd/solid, flat tappet or roller), lift and duration (adv and @.050") 235 / 246. Lykins Custom Hyd roller
   Lifters brand, type: morel
   Timing chain and timing cover: cloyes
   Cylinder heads brand, material, port and chamber information: OTB TFS
      Intake               Exhaust
      .100               .100
      .200               .200
      .300               .300
      .400               .400
      .500               .500
      .600               .600
      .700               .700
      .800               .800
   Flow bench used, location:
   Intake valve brand, head size, stem size:
   Exhaust valve brand, head size, stem size:
   Valve springs brand, part number, specs:
   Retainers and locks brand, part number, specs:
   Rocker arm brand, type (adjustable or non-adj), material, ratio : Lykins
   Rocker shafts and stands, brand, material: POP
   Pushrods brand, type, length: Manton  11/32  .120 wall
   Valve covers, brand, type: CJ aluminum
   Distributor brand, advance curve information: Dura spark
   Harmonic balancer brand: Power Bond
   Water pump brand, type (mechanical or electric): aluminum electric on Dyno
   Intake manifold brand, material, porting information: Streetmaster home ported
   Carburetor(s) brand, type : 780 quick fuel
   Exhaust manifolds or headers brand, type: 2” dyno headers then switched to hooker 6114
[/quote]
« Last Edit: May 24, 2024, 08:48:53 AM by 69ramair »
Re: 464 fe
« Reply #1 on: May 23, 2024, 11:21:37 PM »
Should go real nice in a Stang I suppose
Re: 464 fe
« Reply #2 on: May 24, 2024, 08:12:52 AM »
Very nicely done!
1968galaxie
Re: 464 fe
« Reply #3 on: May 24, 2024, 03:25:08 PM »
The old streetmaster looks to work quite well!
TwoFifty
Re: 464 fe
« Reply #4 on: December 02, 2025, 02:16:57 PM »
Sorry to dig up an earlier thread.  Tried sending a PM direct to 69RamAir but got outsmarted by the tests to ensure I'm human (go figure).
Question to 69RamAir is whether you'd be willing to share what the before/after testing looked like between the 2" dyno header runs compared to the 6114 header runs on the dyno.  If I read it correctly it looked like you may have tried both on the dyno?
I'm intrigued to see what "street headers" cost for power on a combo with this size/power.
Thanks!
69ramair
Re: 464 fe
« Reply #5 on: December 03, 2025, 01:57:40 PM »
Hello TwoFifty. I would be happy to post the dyno pulls for both sets of headers but I tried with both my IPad and IPhone and I wasn’t able to maybe if I could send the pictures to someone they could post them for me
Re: 464 fe
« Reply #6 on: December 04, 2025, 08:06:39 AM »
You can email them to me and I'll post them, jayb@fepower.net.
69ramair
Re: 464 fe
« Reply #7 on: December 04, 2025, 10:19:26 AM »
Thanks Jay email sent
Re: 464 fe
« Reply #8 on: December 04, 2025, 11:09:14 AM »
Dyno headers on the first sheet, Hooker 6114 on the second.  Couldn't get these files to rotate properly, but you can still read them.  Looks like the engine prefers a smaller tube header for torque, and also for average power and average torque.  Not a big difference though - Jay
Re: 464 fe
« Reply #9 on: December 04, 2025, 02:54:46 PM »
2" Dyno Headers
Hooker 6114
« Last Edit: December 04, 2025, 02:57:39 PM by cjshaker »
69ramair
Re: 464 fe
« Reply #10 on: December 04, 2025, 08:24:31 PM »
I would’ve thought that the dyno headers would do better than the hookers just wondering if maybe the streetmaster intake is holding it back a little
Re: 464 fe
« Reply #11 on: December 04, 2025, 09:01:06 PM »
Based on my intake testing the Streetmaster intake does begin to be a bottleneck around 550 HP.  But I've tested a couple of similar engines, both with out of the box Trick Flow heads and better intakes, and they didn't do any better, both around 595 HP.  To me the combination looks pretty well matched, and probably more than just headers would be required to take it up much higher.
69ramair
Re: 464 fe
« Reply #12 on: December 05, 2025, 02:53:54 PM »
Thanks for the comment Jay it does drive very nice on the street so I think I will leave it as is and upgrade the transmission from a C6 to a c4 or a Broader AOD or 4R70W
Re: 464 fe
« Reply #13 on: December 06, 2025, 07:41:58 AM »
I'm very happy with those results.  Almost 600 hp with out of the box heads, small cam, low compression.
TwoFifty
Re: 464 fe
« Reply #14 on: December 08, 2025, 04:52:44 PM »
Thanks for posting up the back-to-back!  For the planned build I'm after it looks like the 6114's already on the car shouldn't be a hindrance to the point where it justifies replacement.  Looks like a great combination!
