Author Topic: What pulleys were on a 427 sohc  (Read 9666 times)
1932fe
« on: July 23, 2013, 12:20:47 AM »
Hi
Wondering what front pulleys on the water pump and crank, only looking for single grove ones  were on the 427 sohc , as am looking for stock or similar stock for the coupe engine, I have heard  61-62 thunderbird , as well as 61-62 galaxies, anyone have some insight to this, As cant run after market  ones as not the right look for engine style.
Thanks Paul
hotrodfeguy
Re: What pulleys were on a 427 sohc
« Reply #1 on: July 24, 2013, 11:04:07 PM »
I know the WP is 61 T-bird. I was going to build a cammer one day but have decided to go full tilt wedge. With a help from a few friends :)
« Reply #2 on: July 25, 2013, 07:35:41 PM »
Here is the crankshaft pulley info, courtesy of my old friend SOHC Bob (RIP):
The Sohc parts
C4AE-6316-E Damper Assy Crankshaft Vibration 4000-4400 CPM -1
C5AE-6A359-F Crankshaft Pulley Outer - 1
Screw And Washer Assy 374525 (Attach Pulley To Damper) - 3
1932fe
« Reply #3 on: July 25, 2013, 07:43:27 PM »
Thank you both for the info just what was needed Thanks Paul
hotrodfeguy
« Reply #4 on: July 28, 2013, 09:26:21 AM »
Are you building one?
hotrodfeguy
« Reply #5 on: July 29, 2013, 11:33:02 AM »
Is the B anything like the E ?
1932fe
« Reply #6 on: July 29, 2013, 02:02:17 PM »
Hi
Yes I am building  one as far as all the outer dimensions are concerned , as we have very little room so I need to know all external measurements to see how the engine sit in the rails,  Have so  far seen we may have to change steering box. Barry R  is going to do the final  build for me.
hotrodfeguy
« Reply #7 on: September 22, 2013, 10:52:22 PM »
Isn't the water pump C1SE-6A301-B
