Author Topic: Comp 938-16 springs  (Read 2359 times)
MeanGene
Comp 938-16 springs
« on: January 15, 2024, 09:58:23 PM »
Somewhere along the line I have accumulated a couple sets of Comp 938-16 valve springs, and trying to nail down their usage. They seem to be an oval-track solid roller spring, I've seen some usages for around .660 lift. Has anyone used these, and what are their limits for cam size and RPM in a large-valve FE ? Can they also be used on a higher lift solid FT cam with tool steel lifters? Thanks
Re: Comp 938-16 springs
« Reply #1 on: January 16, 2024, 08:52:41 AM »
You’d have to measure one and see where it binds up at.  200 lbs seat and 515 at .650” lift is what’s advertised.
Too much, IMO, for a flat tappet and tool steel lifters.  Would work for a steel cam and DLC coated tool steel lifters though.
MeanGene
« Reply #2 on: January 16, 2024, 10:40:44 AM »
Thank you kind sir- yeah, that's what came up on a few roundy-rounder forums for lift, mid to high .600's. Sounds like a good job for my "new" Intercomp spring tester  ;) I have a .687 solid roller, sounds like they would match up well
« Reply #3 on: January 16, 2024, 10:53:26 AM »
Too much lift and not enough spring load for a solid roller with that spring.
That spring would work with a limited travel hydraulic roller, but probably not much else with an FE due to valve weight.
