Author Topic: FE "block print" for lifter bore spacing  (Read 2587 times)
XR7
« on: December 03, 2023, 03:45:22 PM »
I thought I had a copy of the block print for the lifter bore spacing. I can't find it and/or lost it... I have a partial print for some reason but don't have the full view (see attachment). Can anyone share that with me please? Higher the resolution the better. Thanks.
Re: FE "block print" for lifter bore spacing
« Reply #1 on: December 03, 2023, 04:38:45 PM »
The lifter bore spacing for all FE's, including 427 MR, is 1.98. The same as the LR valve spacing.
On the print subtract 1.145 from 3.125, that is the bore spacing.
XR7
« Reply #2 on: December 03, 2023, 05:18:41 PM »
Thanks, I know that, but I wanted all the running dimensions, cumulative, for all bores running down the bank, the bank angle etc. This is for a CNC machine, that doesn't have the FE program. I am hoping someone has the full image of the print.
Tunnelwedge
« Reply #3 on: December 04, 2023, 05:01:23 AM »
XR7
« Reply #4 on: December 04, 2023, 12:27:50 PM »
 :)  Thank you sir!
