Author Topic: Wanted .. distributor spring for FE  (Read 2398 times)
winr1
« on: June 01, 2023, 12:20:42 AM »
Need a distributor spring for an FE .. not the big one but the smaller one
Have 2 Mr Gasket springs and my mech. advance is coming in a bit to early
Searched online and not sure if anything I found would work, the specs were not clear
Ricky.
FERoadster
Re: Wanted .. distributor spring for FE
« Reply #1 on: June 01, 2023, 10:32:23 PM »
Ricky: I've got at least 20 FE distributors. Ford. Motorcraft Mallory Accel and others. How do I figure out which spring you need?
Free including shipping.
Saw your wanted for an FE block on HAMB, but I'm to far away. It would be free except shipping.
FERoadster
winr1
« Reply #2 on: June 02, 2023, 01:10:30 AM »
Hey Richard  :)
Sorry was not clearer
It is a Ford single point with vacuum advance
It originally had a small spring that stretched out a bit to install and a heavier spring that was a lose fit
I need a small spring that has to stretched out a bit to install
I cleaned out my storage and brought a bunch of stuff home, need anything ??
Ricky.
« Last Edit: June 02, 2023, 01:31:16 AM by winr1 »
FERoadster
« Reply #3 on: June 02, 2023, 09:29:35 AM »
OK I did message you just now. I'll pull a vacuum advance distributor off the shelf and message you a picture.
Richard
winr1
« Reply #4 on: June 10, 2023, 05:23:29 PM »
I brought home my Daddy an I's storage stuff, found a spring from an old distributor
Forgot all the old small block an FE stuff, bunch of stuff marked C2 and up, alts, starters an such
Ricky.
